Jeff Diemer 5 #1 Posted July 3, 2023 Looking for Toro p# 116636-03 shift fork for 8 speed transaxle. Several sights listing as discontinued by Toro. Others that say they have stock do not. Any help out there with a source ? Or is it going to turn into a fab your own job. thanks Share this post Link to post Share on other sites
Sparky-(Admin) 22,060 #2 Posted July 3, 2023 Get into our classified section and hit up a couple of our vendors like A-Z Tractor of K and B Wheel Horse. These guys have STUFF! 2 Share this post Link to post Share on other sites
squonk 42,531 #3 Posted July 4, 2023 If you can't find one, sometimes they can be repaired. Share this post Link to post Share on other sites
WHX?? 50,722 #4 Posted July 4, 2023 (edited) Talk to Lowell https://www.google.com/search?q=wheel+horse+parts+and+more&client=ms-android-uscellular-us-revc&sourceid=chrome-mobile&ie=UTF-8#sbfbu=1&pi=wheel horse parts and more Or put an add in wanted. Edited July 4, 2023 by WHX?? 2 Share this post Link to post Share on other sites
Tonytoro416 1,096 #5 Posted July 4, 2023 Rebuilt a 5060 6 speed this last winter that had a broken fork. A-Z is where I got the majority of parts for that transmission. Little harder to find but he had them. Definitely check him out he normally has used and new parts. So you have a little choice in price 1 Share this post Link to post Share on other sites
stevasaurus 23,063 #6 Posted July 4, 2023 (edited) N875ED from Ohio ordered one from TORO in Nov, 2019. I'll bet hey still have them. $57 back then new. TORO #7209. Where did you get that part number #3116636-03 ??? The #7209 is the shift fork number. Maybe #3116636-03 is for all the hi/low shift parts together. Edited July 4, 2023 by stevasaurus Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #7 Posted July 4, 2023 7209 replaced by 116636-03 https://www.partstree.com/parts/toro-commercial-7209/ 1 1 Share this post Link to post Share on other sites
stevasaurus 23,063 #8 Posted July 4, 2023 Thanks gwest. Maybe some of the dealers don't know about the number change. Share this post Link to post Share on other sites
PWL216 940 #9 Posted July 4, 2023 (edited) I have a set of forks from a 312-8. Would that work? Edited July 5, 2023 by PWL216 Share this post Link to post Share on other sites
Jeff Diemer 5 #10 Posted July 5, 2023 Thank you for all the replies and info. Following up on each. Share this post Link to post Share on other sites
squonk 42,531 #11 Posted July 5, 2023 22 hours ago, PWL216 said: I have a set of forks from a 312-8. Would that work? No. hi -lo fork looks like this. 1 Share this post Link to post Share on other sites
PWL216 940 #12 Posted July 6, 2023 16 hours ago, squonk said: No. hi -lo fork looks like this. Thx Squonk, you’re right. Thx for the correction. I’ll look tonight if I have the hi lo 1 Share this post Link to post Share on other sites
Jeff Diemer 5 #13 Posted July 9, 2023 After striking out finding new I went for the repair. carefully removed the old plate to use as template. 1-14/" hole saw, 3/4" drill, piece of .125 steel ,some red dykem and some grinding and filing I have a working fork. the steel was thicker then the original and I had to thin down the area where it fits the gear but maybe it it will be a little stronger. The old plate was bent pretty good but it is only 43 years old. Transmission now back together and shifting feels good.Test drive in a couple more weeks. 1 4 Share this post Link to post Share on other sites
