JPWH 6,250 #26 Posted July 4, 2023 11 minutes ago, wallfish said: Are you thinking 1" spindles into a 3/4 axle hole? They are 7/8 spindles. From a 1054. Share this post Link to post Share on other sites
19richie66 17,560 #27 Posted July 4, 2023 1 minute ago, JPWH said: They are 7/8 spindles. From a 1054. I have three gt14 front axles laying here. Wish you were closer 3 Share this post Link to post Share on other sites
JPWH 6,250 #28 Posted July 4, 2023 8 minutes ago, 19richie66 said: I have three gt14 front axles laying here. Wish you were closer Thanks Richie, I thought about getting a 953 or similar axle but the one I want to use is 2" longer and only has a 3" drop. I think that axle would make the frame too high? I may have to build an axle to get the width I need. Share this post Link to post Share on other sites
JPWH 6,250 #29 Posted July 5, 2023 8 hours ago, 19richie66 said: I have three gt14 front axles laying here. Wish you were closer @19richie66 would you happen to have any steering arms that would work with the Ross steering? Share this post Link to post Share on other sites
19richie66 17,560 #30 Posted July 5, 2023 2 hours ago, JPWH said: @19richie66 would you happen to have any steering arms that would work with the Ross steering? Not that I’m aware of. 1 Share this post Link to post Share on other sites
Pullstart 64,411 #31 Posted July 5, 2023 12 hours ago, JPWH said: They are 7/8 spindles. From a 1054. you know, the non-Ross 953/1054/GT14 steering gear is pretty stout as well. Once I begin rebuilding mine, I think I’ll swap over to that steering vs traditional 1 1 Share this post Link to post Share on other sites
wallfish 17,445 #32 Posted July 5, 2023 11 hours ago, JPWH said: @19richie66 would you happen to have any steering arms that would work with the Ross steering? How about something like this? This what I was thinking for getting around the big tires and under the frame for the engine up front. Use new heim joints for the tie rods 2 Share this post Link to post Share on other sites
Sparky-(Admin) 21,986 #33 Posted July 5, 2023 On 7/1/2023 at 8:48 AM, Ed Kennell said: Wasn't there a large dump truck build started at the 2022 show? Yep… 2 5 2 Share this post Link to post Share on other sites
JPWH 6,250 #34 Posted July 5, 2023 The 50 minutes ago, wallfish said: How about something like this? This what I was thinking for getting around the big tires and under the frame for the engine up front. Use new heim joints for the tie rods That looks complicated. I think by raising the frame and a wider axle then maybe incorporating your heim joints that may work. Share this post Link to post Share on other sites
Ed Kennell 40,373 #35 Posted July 5, 2023 4 hours ago, Sparky said: Yep… I thought this was to be the 2023 raffle tractor. Any update on the status? 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,986 #36 Posted July 5, 2023 I heard the same thing about it being the 2023 raffle rig. Maybe it wasnt completed?? 1 1 Share this post Link to post Share on other sites
JPWH 6,250 #37 Posted July 6, 2023 I laid out the build on the shop floor and the frame is going to be +/- 8'. I ordered the 2x2x3/8 angle iron for the frame today and dug around on the metal storage rack and found a piece of 2x3x1/4 tube steel to make the axle and some round stock to make the spindle and axle pin supports. I may get started sticking metal together this weekend. 2 2 Share this post Link to post Share on other sites
wallfish 17,445 #38 Posted July 6, 2023 I'm still torn between low and hot roddie fast (35-40 mph) or big powerful with lots of torque and slow. Maybe UTV type with some tube frame ????? 8 ft is a long one. You'll need to position the Ackerman angle for the steering arms correctly so it tracks and steers right so it helps with the steering radius. https://en.wikipedia.org/wiki/Ackermann_steering_geometry There's lots of crazy math out there for it but go by this simple diagram and it works great for our low speed non space shuttle tractors. 3 2 Share this post Link to post Share on other sites
JPWH 6,250 #39 Posted July 6, 2023 3 hours ago, wallfish said: I'm still torn between low and hot roddie fast (35-40 mph) or big powerful with lots of torque and slow. Maybe UTV type with some tube frame ????? 8 ft is a long one. I'm going for 2 seater garden tractor that looks like a dump truck. The wheel base should be about 6'. I'm going for a 3x5 dump bed but I'm short legged at 5'7" so it may shorten up a little. I don't have a supply of parts tractors so the tires may need to be sourced new. Maybe dual ags and tri ribs. I was checking out the Ackerman angle and was intending to use the diagram you show as a starting point and go from there. 2 Share this post Link to post Share on other sites
ebinmaine 70,494 #40 Posted July 6, 2023 At low speeds it won't hurt much to have the wheelbase a touch too long for a given Ackerman angle. Our long wheelbase semi trucks are a prime example. At. Low. Speeds. When I'm turning very sharp into a parking spot or driveway the front of the trucks definitely scrubs some. Unavoidable. That scrubbing can be negated some on a tractor by making the front wheels tilt out at the top a few degrees. I found that on some farm tractors and built the spindles for Colossus that way. Using a tri-rib tire will also help a fair amount. 3 1 Share this post Link to post Share on other sites
wallfish 17,445 #41 Posted July 6, 2023 These old Toro Golf coarse tractors were cool But somehow mine will end up looking something like this 1 1 9 2 Share this post Link to post Share on other sites
c-series don 9,413 #42 Posted July 6, 2023 Nothing about that picture is OSHA approved! 2 2 Share this post Link to post Share on other sites
ebinmaine 70,494 #43 Posted July 6, 2023 12 minutes ago, c-series don said: Nothing about that picture is OSHA approved! Here in Hill country those letters have a slightly different meaning: Only Safety Hazards Allowed But... on the other hand it appears they have a fairly decent, Overhead Safety Hazard Avoidance System in place. 6 Share this post Link to post Share on other sites
SylvanLakeWH 27,351 #44 Posted July 6, 2023 Trail cam at @Pullstart's in about 30 years... he's gone full native and doesn't even wear his steel toed flip flops anymore... 11 Share this post Link to post Share on other sites
Pullstart 64,411 #45 Posted July 6, 2023 @SylvanLakeWH if I were to go full native, there would be a blurred center section. At least he’s got his safety skivies on! 1 10 Share this post Link to post Share on other sites
c-series don 9,413 #46 Posted July 6, 2023 How did I know Kevin would be dragged into this 🤣 1 6 Share this post Link to post Share on other sites
Pullstart 64,411 #47 Posted July 7, 2023 Can’t be my charming smile @c-series don! 2 Share this post Link to post Share on other sites
19richie66 17,560 #48 Posted July 7, 2023 (edited) Why did I get involved with this thread? Now you got me wanting to stretch the D and put a bed on it. If I did that though, I could lower the 3 speed transmission in the frame and use a belt on the front and a small driveshaft to the rear axle. Edited July 7, 2023 by 19richie66 1 1 3 Share this post Link to post Share on other sites
JPWH 6,250 #49 Posted July 7, 2023 56 minutes ago, 19richie66 said: Why did I get involved with this thread? Now you got me wanting to stretch the D and put a bed on it. If I did that though, I could lower the 3 speed transmission in the frame and use a belt on the front and a small driveshaft to the rear axle. So your upping the game with a tandem axle? Go for it I'll follow along. Share this post Link to post Share on other sites
Handy Don 13,321 #50 Posted July 7, 2023 8 minutes ago, JPWH said: So your upping the game with a tandem axle? Go for it I'll follow along. Tandem. Follow. Good one! 1 Share this post Link to post Share on other sites
