eddiebunyan 24 #1 Posted June 29, 2023 Are these wheel horse lights? 1 Share this post Link to post Share on other sites
ebinmaine 69,262 #2 Posted June 29, 2023 What's that outta? Share this post Link to post Share on other sites
wallfish 17,141 #3 Posted June 29, 2023 Might be for a Black Hood but it would help to see the other side. The bulbs will fit WH as they're standard size Like someone broke the retaining clips and replaced it with the metal and screws to hold them 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,612 #4 Posted June 30, 2023 Yes they are. Used in the blackhood series. The metal brackets holding in the lamp is the real deal. If you blow up the pic you can see the other style of clip in the open hood. 4 Share this post Link to post Share on other sites
wallfish 17,141 #5 Posted June 30, 2023 The set I have has the usual little spring tabs to hold the bulbs in place. I like those metal pieces better 2 Share this post Link to post Share on other sites
eddiebunyan 24 #6 Posted June 30, 2023 2 hours ago, ebinmaine said: What's that outta? 1 Share this post Link to post Share on other sites
eddiebunyan 24 #7 Posted June 30, 2023 Other side. Specifically what model tractors? 1 Share this post Link to post Share on other sites
ineedanother 1,369 #8 Posted June 30, 2023 My '84 black hood has the annoying little spring tabs but I think I could upgrade to that pretty easily. I like it 2 Share this post Link to post Share on other sites
ebinmaine 69,262 #9 Posted June 30, 2023 6 hours ago, eddiebunyan said: Other side. Specifically what model tractors? C 1x5 series. 1980 to 84 I think? Your metal pieces are a great replacement for the tabs. 1 Share this post Link to post Share on other sites
peter lena 8,933 #10 Posted June 30, 2023 @eddiebunyan like those metal brackets , that metal to plastic set up , just steadily starts to , break apart . good spot to do an improvement on . also used that as the end ground improve ment point for engine related ground verifacation . basically , connecting from battery ground bolt , to and needed ground area . lights . ignition , etc . do not count on painted / rusty , cooling tins to hold a ground . once I started doing that , simply added it to all my stuff . your amperage gauge will also wake up , with better grounding . simple test improvement , is an alligator clip wire from battery ground bolt to related ground test spot . only a suggestion . pete 1 Share this post Link to post Share on other sites
ranger 1,769 #11 Posted June 30, 2023 (edited) My 312-8 had the same type lights, also Westwood GT’s, + some full size tractors used them for plow lights, I think? Single filament! 5-3/4” diameter. My Sunbeam Rapier used them as high beam lights too. Edited June 30, 2023 by ranger 1 Share this post Link to post Share on other sites
eddiebunyan 24 #12 Posted June 30, 2023 I don't have a tractor that these fit.My first question was if they were indeed wheel horse lights and second what would they be worth? Share this post Link to post Share on other sites
c-series don 9,178 #13 Posted June 30, 2023 The bulbs are standard GE 4411, available at most auto parts stores. The bulb holder $25 1 Share this post Link to post Share on other sites
