mrtortoise 3 #1 Posted June 25, 2023 Hello, I would like to tow logs with my Raider 10 - can anyone tell me what type of towing attachment I need please? Thanks, Paul. Share this post Link to post Share on other sites
SylvanLakeWH 26,538 #3 Posted June 25, 2023 (edited) How big and how far? Strap / chain will do the trick for short distances directly from the draw bar. I've used my utility cart and strapped just the front in the cart and let them drag behind and dragged them out that way. You can see in the back of this picture. Edited June 26, 2023 by SylvanLakeWH 4 Share this post Link to post Share on other sites
ebinmaine 69,656 #4 Posted June 25, 2023 15 minutes ago, SylvanLakeWH said: How big and how far? We actually stopped twitching logs because I don't like the dirt in my chainsaws but it fascinates me to see others do it. 1 2 Share this post Link to post Share on other sites
Achto 28,154 #5 Posted June 26, 2023 Anything that will keep the front of the log from digging in to the dirt while you pull it. 2 Share this post Link to post Share on other sites
peter lena 8,960 #6 Posted June 26, 2023 @mrtortoise have a kids plastic snow slide ? combine that with a chain grab off your rear hitch ,also use your gearing to see how it moves / reacts to your intended idea. done a lot of that , NO WHEELIES ALLOWED ! stay safe , pete 3 Share this post Link to post Share on other sites
Handy Don 13,040 #7 Posted June 26, 2023 For keeping them clean, you need a log arch, like in Ed’s post, that keeps the log from dragging in the dirt. Otherwise, any of the other suggestions can work. 2 Share this post Link to post Share on other sites
ebinmaine 69,656 #8 Posted June 26, 2023 2 hours ago, Handy Don said: For keeping them clean, you need a log arch, like in Ed’s post, that keeps the log from dragging in the dirt. Otherwise, any of the other suggestions can work. Only short logs unless you have a double ended Arch. 1 Share this post Link to post Share on other sites
mrtortoise 3 #9 Posted June 27, 2023 Thank you all responders! I'm new to the world of the Wheel Horse and this forum is fantastic. One final question is this: what type of attachment do I need to use to hold the chain or rope in place? P. 1 Share this post Link to post Share on other sites
ebinmaine 69,656 #10 Posted June 27, 2023 5 minutes ago, mrtortoise said: Thank you all responders! I'm new to the world of the Wheel Horse and this forum is fantastic. One final question is this: what type of attachment do I need to use to hold the chain or rope in place? P. If you have a regular tab style hitch you can just grab a bolt with an eyelet or use a clevis pin, either with a hairpin through the bottom or with a locking bar around it. Lots of things will work. 3 Share this post Link to post Share on other sites
mrtortoise 3 #11 Posted June 27, 2023 Thank you Eric. 1 Share this post Link to post Share on other sites
ebinmaine 69,656 #12 Posted June 27, 2023 Have you decided what type of pulling mechanism to use? Share this post Link to post Share on other sites
SylvanLakeWH 26,538 #13 Posted June 27, 2023 37 minutes ago, ebinmaine said: If you have a regular tab style hitch you can just grab a bolt with an eyelet or use a clevis pin, either with a hairpin through the bottom or with a locking bar around it. Lots of things will work. Here's a simple hook I use on the drawbar with a strap or chain... couple bucks at Harbor Freight... 2 Share this post Link to post Share on other sites
mrtortoise 3 #14 Posted July 9, 2023 Thanks everyone who helped - I also found this amazing shop which does logging kit - I bought a choker chain and D shackle whick worked perfectly: https://www.chrisforestry.co.uk/store/Chokers-c34052190 P. 1 Share this post Link to post Share on other sites
