ChickenPoop 15 #1 Posted June 18, 2023 Hey all. I need some input. I recently purchased a wheel horse with a Kohler K341. I’ve been running it for a bit doing chores around the house. Not a whole lot though. I cleaned the carb when I got it. It was full of rust/flakes. It hasn’t performed to well under heavier loads especially when going up hill. It seemed it would surge a little bit but ran fine unloaded. I finished mowing my small field yesterday when the engine suddenly sound different. I stopped to listen to it and a second later there was a loud clunk. I shut it down immediately. It took longer than normal to shut off completely. I pulled the dipstick and noticed some smoke coming out. There wasn’t hardly any oil on the stick and it was black. I gave it a few minutes and turned the key. It turned and kept spinning freely. I understand I shouldn’t have trusted the person I bought it from to keep everything topped off and I should have checked myself. Lesson learned. I understand the basics of engines and maintenance but I’ve never tore into an engine to far besides most basic maintenance. My guess is there’s zero compression with the way it spins freely when I try to start it. I ordered a compression gauge to be sure but any help from y’all would sure be appreciated! 2 Share this post Link to post Share on other sites
squonk 41,365 #2 Posted June 18, 2023 Sounds like a rod broke. The clue is "it took longer to shut off" 3 2 Share this post Link to post Share on other sites
wallfish 17,083 #3 Posted June 18, 2023 You can easily check for compression by removing the spark plug completely. Use you finger or thumb to block the hole and have someone hit the key to start. it should blow your finger out of the hole pretty quickly. A gauge is import for further diagnosis. Just keep the plug wire away so you don't get a jolt. If your finger stays in the hole while the engine is turning then something big, like a broken rod happened. With low oil like that it probably seized to the crank and snapped it. 5 Share this post Link to post Share on other sites
Ed Kennell 38,687 #4 Posted June 19, 2023 No question, the crank bone is no longer connected to the piston bone. I wouldn't crank it with pieces of the rod bone flopping around. 14 hours ago, ChickenPoop said: . It turned and kept spinning freely. 1 2 Share this post Link to post Share on other sites
Pullstart 63,100 #5 Posted June 19, 2023 Is it the black hood in this thread? Unfortunately you may be best off looking for another “shaker plate” engine or plan to visit some small engine shops or automotive machine shops for rebuild quotes. I am not sure if @richmondred01 can help? He at one point had a high enough inventory of high quality rebuilds to be able to ship. 1 Share this post Link to post Share on other sites
WHX?? 49,177 #6 Posted June 19, 2023 Where's that video of @Rp.wh throwing a rod on the plow field when you need it. 1 2 Share this post Link to post Share on other sites
richmondred01 2,239 #7 Posted June 19, 2023 Sounds like a rod. I don’t have any 16 hp in stock. I can rebuild yours. The rod may have chipped the apron skirt when it broke. If that’s the case I sleeve the cylinder. Not a problem, unless the block is cracked, I can rebuild it. PM me for details. 4 Share this post Link to post Share on other sites
Jon Paulsen 290 #8 Posted June 19, 2023 4 hours ago, WHX?? said: Where's that video of @Rp.wh throwing a rod on the plow field when you need it. Will this 8 HP video work until you can locate @Rp.wh s proper rod tossin' vidjo? Everyone loves to watch someone els's enjin toss parts out the case. 1 1 Share this post Link to post Share on other sites
ChickenPoop 15 #9 Posted June 19, 2023 Fun little update. Tore the motor apart. The cylinder wall and valves made out good. The rod is no longer with us. Looks like two of the gears had some chunks break off though. Share this post Link to post Share on other sites
richmondred01 2,239 #10 Posted June 19, 2023 Most likely the bearings will also need to be replaced. When the rod breaks small pieces of aluminum get into the bearings. The crack can be brought back and ground. Not a problem. check the bottom of the apron skirt and see if it’s chipped. Removed those balance gears. Also simply saying the walls look good doesn’t cut it. You need to get a cylinder bore gauge and measure it. 1 Share this post Link to post Share on other sites
ChickenPoop 15 #11 Posted June 19, 2023 8 hours ago, Pullstart said: Is it the black hood in this thread? Unfortunately you may be best off looking for another “shaker plate” engine or plan to visit some small engine shops or automotive machine shops for rebuild quotes. I am not sure if @richmondred01 can help? He at one point had a high enough inventory of high quality rebuilds to be able to ship. Yes, it’s the black hood from that thread. Share this post Link to post Share on other sites
ChickenPoop 15 #12 Posted June 19, 2023 1 hour ago, richmondred01 said: Most likely the bearings will also need to be replaced. When the rod breaks small pieces of aluminum get into the bearings. The crack can be brought back and ground. Not a problem. check the bottom of the apron skirt and see if it’s chipped. Removed those balance gears. Also simply saying the walls look good doesn’t cut it. You need to get a cylinder bore gauge and measure it. I’m wondering where y’all stand on the balancing gears. I’ve read up on it a little. Seems like I can leave ‘em or get rid of them. From what I’ve read, sounds like the risk of them failing and causing more damage isn’t worth what little vibrations they reduce? Share this post Link to post Share on other sites
richmondred01 2,239 #13 Posted June 19, 2023 Take them out. 1 Share this post Link to post Share on other sites
WHX?? 49,177 #14 Posted June 19, 2023 Only the most hardcore purist would leave them in. not one of Kohler's better mouse traps. 1 Share this post Link to post Share on other sites
squonk 41,365 #15 Posted June 20, 2023 2 hours ago, ChickenPoop said: I’m wondering where y’all stand on the balancing gears. I’ve read up on it a little. Seems like I can leave ‘em or get rid of them. From what I’ve read, sounds like the risk of them failing and causing more damage isn’t worth what little vibrations they reduce? You have a broken gear. It isn't balanced anymore. 1 Share this post Link to post Share on other sites
Tuneup 1,433 #16 Posted June 20, 2023 I can't tell. Are those balance gears really broken? If not, send them to me. I'm becoming a purist. Share this post Link to post Share on other sites
pfrederi 17,887 #17 Posted June 20, 2023 I will take a contrarian view here. Based on all the recommendations here I left the balance gears out of a K341 that I overhauled. The engine has a very pronounced buzzy vibration now that gets to be uncomfortable after a couple hours of mowing... Next big block overhaul will keep balance gears and get new bearings for them. Share this post Link to post Share on other sites
Wild Bill 633 849 #18 Posted June 20, 2023 (edited) I would think re-balancing the crank would allow the balance gears to be removed. Edited June 21, 2023 by Wild Bill 633 1 Share this post Link to post Share on other sites
squonk 41,365 #19 Posted June 20, 2023 6 hours ago, Wild Bill 633 said: I would think re-balancing the crank allow the balance gears to be removed. The crank, rod and piston are balanced at the factory. Once you change a part the balance off to some degree. Balancing the crank would probably help but it won't be like brand new. Share this post Link to post Share on other sites
RED-Z06 2,247 #20 Posted June 24, 2023 I left my gears in on a 197hr old engine that broke a governor gear...i wish id left them out Share this post Link to post Share on other sites
ChickenPoop 15 #21 Posted June 26, 2023 We’ll I got a new piston, rings, and rod installed. Put new oil in. She started right up but started throwing white smoke pretty bad. Turns out I over filled the oil a tad. Drained some and got it just below full on the dipstick. Still throwing a lot of smoke. Can anyone point me in the right direction? Share this post Link to post Share on other sites
squonk 41,365 #22 Posted June 26, 2023 Did you hone the cylinder before installing the piston and rings? Share this post Link to post Share on other sites
rmaynard 15,610 #23 Posted June 26, 2023 Hope you put the rod cap on correctly with the oil hole toward the cam, or you will be doing this all over again. Share this post Link to post Share on other sites
ChickenPoop 15 #24 Posted June 26, 2023 What a way to learn! I’m going to know this engine inside out by the end of this! 1 Share this post Link to post Share on other sites
ChickenPoop 15 #25 Posted June 26, 2023 44 minutes ago, squonk said: Did you hone the cylinder before installing the piston and rings? No. Suppose I’ll be ordering a honing brush. 1 Share this post Link to post Share on other sites
