WARREN 53
269H electric/hydro lift trouble
WARREN 53
Hi, I have 269H where the electric lift  motor runs but the piston only moves less than an inch when trying to raise the mower deck.  I took the deck off and the piston sometimes extended very sluggishly if I held the switch. It lowers/retracts normally. I checked the fluid level in the motor. I cannot see or find any fluid leak from any connections.  Any ideas of what may be wrong.  Bad piston or pump?  Thanks
gwest_ca
Do you have the lift service manual?
WARREN 53
I do now, thanks. Just downloaded it.
