Joker72 64 #1 Posted June 12, 2023 (edited) Does anyone know what size the drive belt is or the proper replacement for it? Need to replace mine. Edited June 12, 2023 by Joker72 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #2 Posted June 12, 2023 Tractor drive belt # 7478 replaces # 4535 - (HB/5L x 84.22" or 5/8" x 84.22") 2 1 Share this post Link to post Share on other sites
ri702bill 8,967 #3 Posted June 12, 2023 Garry - can he use a 5/8 x 84" instead - easier to find...?? Share this post Link to post Share on other sites
squonk 42,522 #4 Posted June 12, 2023 31 minutes ago, ri702bill said: Garry - can he use a 5/8 x 84" instead - easier to find...?? Yes. I run a Tractor Supply 84" belt on my 76 C 160 1 1 Share this post Link to post Share on other sites
peter lena 9,087 #5 Posted June 12, 2023 @Joker72 looks like you are covered on the needed belt info , how about your idler pulley ? critical balance movement point , if its rough in any way , swap it out, would also get some aerosol lubricant into every related movement point , make the rust run out , good oportunity spot , pete Share this post Link to post Share on other sites
