gwood 16 #1 Posted June 9, 2023 I have 3 Wheel Horse tractors needing seats. I've been to Tractor Supply and their bolt patterns don't show 7" wide by 71/2 " front to back and I called Northern Tool and the 3 they have also won't fit. Where have our members found seats for C-160 automatic, C-120 Automatic, etc.? Share this post Link to post Share on other sites
tunahead72 2,587 #2 Posted June 9, 2023 You should be able to find several seats for your tractors. I don't have my notes in front of me, but check your measurements -- somebody please correct me if I'm wrong, but I believe the bolt patterns should be 7-1/2" wide by 7" front to back (the reverse of what you said). Share this post Link to post Share on other sites
Wayne0 1,422 #3 Posted June 9, 2023 The Northern Tool seat fit fine on my 1987 Work Horse. Your instance may vary. Share this post Link to post Share on other sites
8ntruck 8,332 #4 Posted June 9, 2023 I just put a new Tractor Supply seat on my C-195. There was a 7 1/2 wide by 7 long bolt pattern in the seat. I had to drill and tap two holes to match the 7 1/2 wide by 8 long bolt pattern in the seat adjusters. Share this post Link to post Share on other sites
SylvanLakeWH 29,818 #5 Posted June 9, 2023 I've gotten two from AZ Tractor - a vendor on this site. Very nice, comfortable, perfect fit. 1 Share this post Link to post Share on other sites
gwood 16 #6 Posted June 9, 2023 5 hours ago, tunahead72 said: You should be able to find several seats for your tractors. I don't have my notes in front of me, but check your measurements -- somebody please correct me if I'm wrong, but I believe the bolt patterns should be 7-1/2" wide by 7" front to back (the reverse of what you said). Thanks Share this post Link to post Share on other sites
gwood 16 #7 Posted June 10, 2023 5 hours ago, tunahead72 said: You should be able to find several seats for your tractors. I don't have my notes in front of me, but check your measurements -- somebody please correct me if I'm wrong, but I believe the bolt patterns should be 7-1/2" wide by 7" front to back (the reverse of what you said). Thanks all of you who responded! I did screw up on the measurements and they are 71/2" wide x 7" front to back! 1 Share this post Link to post Share on other sites
