5151 11 #1 Posted June 9, 2023 Hi folks, I usually lurk and find my way. Lost my local dealer, Jacks in Sarver Pa, so here I am. I have a belt misbehaving. Do you guys see anything I am missing? 312-H, 1000hrs New drive belt 5/8x82 New bushing on R Side idler shaft Idler pulley good No cracks in frame Eng and trans mounts tight, 4 bolts each PTO bearings checked and greased Trans fluid new 10w30 PTO break set to 12 thou Share this post Link to post Share on other sites
lynnmor 7,514 #2 Posted June 9, 2023 Did it vibrate the same before you replaced the belt? There are plenty of poor quality belts out there. Share this post Link to post Share on other sites
5151 11 #3 Posted June 9, 2023 Yes but that old hat bushing, or step bushing, was in two pieces. The name on the new belt is True Blue. Was not finding much info on the hydro model and wondering if it might want a different belt than the clutch model. I may be overthinking that though. Share this post Link to post Share on other sites
D_Mac 8,966 #4 Posted June 9, 2023 (edited) I'm not knowledgeable on the material the v- belts are made of but I do know when I use a brand new belt that is black in color it jumps and vibrates. So I get the belt that is blue in color and it works fine. Edited June 9, 2023 by D_Mac 1 1 Share this post Link to post Share on other sites
5151 11 #5 Posted June 10, 2023 After third time in I think it is the idler pulley bearing. Older machines with low hours sat a lot. Thanks Lynn and Mac for replies. 1 Share this post Link to post Share on other sites
peter lena 9,023 #6 Posted June 10, 2023 @5151 those original idler pulleys have an undersize bearing , also a very common binding , rough operation . tractor supply has the same size / type flat pulley , with a much larger bearing , and removable bearing side shields , for a clean out and re grease with a hi temp grease . you wiill have to get a 3/8 to 5/8 short bronze bushing to push in to that bearing , that will make it an exact fit , smooth / solid / quiet . would also lubricate all related linkage / connection points , make the rust run out . have that exact set up on my horses , consistantly reliable , pete Share this post Link to post Share on other sites
5151 11 #7 Posted June 11, 2023 (edited) Great info Peter thanks. Tried 2 TS and no luck. I'll try another town. I have the bearing soaking but not real hopeful. Smooth quiet and solid is what I'm aiming for, redid the deck and mule drive over the winter and now chasing down the rest. Edit, bottom spring hookup seems wrong to me, just two nuts there. If there are IPLs of WH I would be thrilled to find them. Edited June 11, 2023 by 5151 Share this post Link to post Share on other sites
5151 11 #8 Posted June 13, 2023 Bearing repacked and back together. Runs much better. Now the spring is kissing the pulley. Grrr lol. Is the wave washer and spring available? Share this post Link to post Share on other sites
5151 11 #9 Posted June 24, 2023 Well I found an OEM NOS idler pulley. Bearings in old one seem on the way out. Anyone know the name or PN for the spring that tensions the drive belt? Share this post Link to post Share on other sites
peter lena 9,023 #10 Posted June 24, 2023 @5151 https://www.google.com/search?q=312+idler+belt+spring&rlz=1C1CHBF_enUS866US866&oq=312+idler+belt+spring&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIHCAE . this help ? also have made up 1/8" or 3/16" round steel rod , to extend spring pull point , bend it into a LONGER " S " SHAPE . letting you get away from the problem area , don,t even think about adding that fix , with a heavier spring . looking right at it , pete Share this post Link to post Share on other sites
5151 11 #11 Posted June 24, 2023 I found it, 107938. Thanks guys, I'm slow with this. 1 Share this post Link to post Share on other sites
peter lena 9,023 #12 Posted June 24, 2023 @5151 just some of the stuff I use , regularly make up an adaptor / enhancemant , go to spot for better function , have not mentioned also adding lubrication to improve function . this is not in the book , I won,t tell anybody if you go there , pete Share this post Link to post Share on other sites
5151 11 #13 Posted July 11, 2023 After all that it's better but still some jump on the idler arm. In belt chart it calls for hb/sl x 81 1/2. Supplier sold me 5/8 x 82. Do you guys think a 1/2 inch matters? Share this post Link to post Share on other sites
peter lena 9,023 #14 Posted July 11, 2023 @5151 aerosol lubricate . make the rust run out of all related , connection areas , then red grease spray , thoas short bronze thru bushings , love aerosol red grease . sounds like a movement point drag / hang up , pete Share this post Link to post Share on other sites
Sailman 1,299 #15 Posted July 12, 2023 19 hours ago, 5151 said: After all that it's better but still some jump on the idler arm. In belt chart it calls for hb/sl x 81 1/2. Supplier sold me 5/8 x 82. Do you guys think a 1/2 inch matters? Don't know if this helps or not. I have a GT 14. I purchased a belt from tractor supply that appeared to be correct. Had issues with tractor not pulling well under load so I replaced the idler spring. Still had issues so I replaced with OEM belt and it has worked much better since. 1 Share this post Link to post Share on other sites
5151 11 #16 Posted July 18, 2023 I do not think the 81 1/2" belt is the answer. Not enough clearance from top of idler pulley to frame. With belt on, I bounce the belt by hand, I hear / feel noise from trans shaft area, Yikes. Anyone do house calls? lol Going to step away for the moment. Share this post Link to post Share on other sites
wallfish 17,247 #17 Posted July 19, 2023 Check the pulley grooves. Both on the engine and the trans/pump. Make sure they're smooth and nothing is stuck on them or chipped or anything. Watch the trans/pump pulley from behind as it's spinning to see if there is any wobble to it. Not common but possible. A stronger spring for the idler won't hurt anything at all but it will help with pulling the "memory" out of a new belt. New belts tend to keep that bend in them from the packaging for little bit until they're worked. Share this post Link to post Share on other sites
5151 11 #18 Posted July 19, 2023 Thanks Wallfish and everyone. I did check the pulleys twice hoping to find something wedged in, nothing. That's a good tip sighting it from behind while running. Spring is new oem. Good point about belt memory. Maybe I'm too fussy. Might get after it tomorrow. Thought of removing the plastic fan and clean and inspect. Share this post Link to post Share on other sites
