rediron
1963 653 belt problems
rediron
Hi everyone needing some help with my grandsons 653 I painted it and got everything pretty much back together and looked up the belt for it ordered it and (1/2x70) and way to small??
I dont know if its ever been modified in any way it was a basket case when I bought it also trying to find a picture of the belt configuration to see if there are some pulleys I dont need to use not running a deck
or anything else just the drive belt any help is appreciated !! Thanks ! I still cant get pictures to my laptop so I have nothing to put on here
Achto
The tractor in this picture is a 701, but you should have the same basic set up. Remember that the clutch will not work properly without the belt guard in place.
WHX??
753 setup here... should be nearly identical. 70" sounds about right.
ri702bill
Great picture of the first year front engine configuration!!
Do check that the idler pulley bearing is free and working well. Same goes for the spring on the brake side - It HAS to provide enough tension for the belt to drive without slipping...
Be sure the drive pulley on the Unidrive is TIGHTLY secured.... and as @Achto mentioned, you MUST use the belt guard....
Bill
  • Thanks 1
rediron
Thanks for the pics and advise, I dont have the guard it didnt come with one any idea how to find one in redsquare I tryed to post in classifieds but I dont think it went through Thanks again you guys are lifesavers!!!
gwest_ca
The 653 is not included here but the 654 is. Perhaps someone with a 653 can provide the measurements.
WHX??
It is posted... I'll check my belt guard pile but doubtful.
