Dreamcatcher
Front Wheel Greasing Tips?
Dreamcatcher
I'm trying to grease both of my tractors and am using the same grease gun I use to grease ball joints and steering linkages on my truck.  The fitting on my gun seems just a little fat and won't latch on the zerks for the front wheels.  Can any suggest any tricks or methods to accomplish this task?
Racinbob
If it fits the others it sounds like some new zerks may be in order. 4 or 5 years ago I cleaned all the grease from the front spindles and installed sealed bearings. I was just curious how long they would last but now I'm sold on them. :)
  • Like 3
squonk
They lasted 2 years on my mowing tractor. 1 failed. Took the rest apart and packed them. Took a new one apart and there wasn't a lot of grease in there either. So packed that one too
ri702bill
I agree with Bob that sealed bearings  - specially if you have an early tractor with bushings, is the way to go. Much cleaner.
Those fittings use a standard 1/4-28 thread and are easy to change.
Years ago, I had replaced both U-joints on one of my RWD vehicles. I used the HD style, with the fatter center cross and a grease fitting. I too could not get a grease gun coupler in there. The solution was a short pipe adapter with a zerk fitting on one end and a ground down tapered coupler on the other. Had to rotate the driveshaft to find the fitting, but it worked fine....
Bill
Edited by ri702bill
squonk
Years ago, I had replaced both U-joints on one of my RWD vehicles. I used the HD style, with the fatter center cross and a grease fitting. I to could not get a grease gun coupler in there. The solution was a short pipe adapter with a zerk fitting on one end and a ground down tapered coupler on the other. Had to rotate the driveshaft to find the fitting, but it worked fine....
Bill
They make a pointy grease gun adapter to get to those u joint zerks.
Performance Tool 4" Grease Gun Needle Nose Adapter W54216 - Advance Auto  Parts
Edited by squonk
Retired Wrencher
I had some one time where there was old paint on top of the zerk. Did not see it at first. I guess look first before you grese.:naughty:
Dreamcatcher
AhhhHaaa! I have one of those.  I will try it out.  Thank you @squonk!
peter lena
@Dreamcatcher in additition to the lubrication verifacation , how much wheel play do you have ? is it sloppy , always take the time to add related wheel axel washers , to secure and hold that wheel, more ofen than not that loose wheel shucking , is trearing up bearing and hub mount spot . prefer lubricated bearings , that I  can easily , maintain . pete
Dreamcatcher
@peter lenaI will check this out and report back
Dreamcatcher
On the subject of wheels.  Do the 310 and 417 have the same wheel sizes?
