cafoose 3,383 #1 Posted June 2, 2023 (edited) Just got finished putting my 54 inch dozer blade on a GT-14. I previously took the electric clutch off and converted it to manual. @Wheel Horse 3D The dash plate doesn't quite fit It's just a worker and it's fine for now https://youtube.com/shorts/H7bLbJD7uzU?feature=share Edited June 2, 2023 by cafoose 3 Share this post Link to post Share on other sites
peter lena 9,088 #2 Posted June 2, 2023 @cafoose did you work / detail lube in that plow quadrant? done that to every plow I had after the first , experimention with that area. proved to be well worth it , also note your plow lever squeeze point , lubrication to every related area , lets you snug / tighten up on the lever connection rod , going to plow frame side. get some red grease in / on the quadrant lever spring pin area , sounds like a rifle bolt , very smooth / solid 1 Share this post Link to post Share on other sites
cafoose 3,383 #3 Posted June 2, 2023 Didn't grease it up yet @peter lena but it's on my list. It's getting hot out now so I'll get to it before I use it when it cools down some. No plans to use it anytime soon. Share this post Link to post Share on other sites
peter lena 9,088 #4 Posted June 2, 2023 @cafoose usually set up my plows on a couple of milk crates , so I can roller stool around them and verify how they work . that quadrant slide pin area is a gold mine for lubrication , soak it down , while its resting , don,t blame me if it comes back to life .pete 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,814 #5 Posted June 2, 2023 3 hours ago, cafoose said: The dash plate doesn't quite fit does that happen to be the imperfect I sent? It should have lined up except for the lower holes though. And that definately looks shy just like before! I set those into the housing! Grumble grumble! All 3 the same? 1 Share this post Link to post Share on other sites
cafoose 3,383 #6 Posted June 2, 2023 1 minute ago, Wheel Horse 3D said: does that happen to be the imperfect I sent? It should have lined up except for the lower holes though. And that definately looks shy just like before! I set those into the housing! Grumble grumble! All 3 the same? I'm just pulling your chain, notice the emoji It's fine for that machine. It's a worker. I was expecting it to be imperfect. I haven't checked the others yet. again for all you do for our Share this post Link to post Share on other sites
Wheel Horse 3D 3,814 #7 Posted June 2, 2023 Lol thank goodness! Ya had me for sure. After a minute I wondered is the new ones had made it yet. LOL 2 Share this post Link to post Share on other sites
cafoose 3,383 #8 Posted June 2, 2023 33 minutes ago, Wheel Horse 3D said: I wondered is the new ones had made it yet I have informed delivery from USPS that lets me know everything coming to me in the mail since I moved to Tennessee. I got an email this morning that it's arriving tomorrow. Share this post Link to post Share on other sites
Wheel Horse 3D 3,814 #9 Posted June 3, 2023 Yay! Let us know even if they DON'T fit! LOL!!! 1 Share this post Link to post Share on other sites
cafoose 3,383 #10 Posted June 3, 2023 (edited) 21 minutes ago, Wheel Horse 3D said: Yay! Let us know even if they DON'T fit! LOL!!! Edited June 3, 2023 by cafoose 1 Share this post Link to post Share on other sites
