John2189 453 #1 Posted May 31, 2023 Ok the plate that bolts to the steering tower is missing along with the serial number. How can I tell what year it is? 1980,81 or 84. Were they not made in 82 and 83? the serial number of the engine says it is a 1983. So that doesn’t help much, it could be a replacement engine for the 80 or 81 or it could be a left over engine for the 84 Is there another place on the tractor that the serial number could be? 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,046 #2 Posted May 31, 2023 Gear or hydro transmission? and if hydro is it a Sundstrand or Eaton? 2 Share this post Link to post Share on other sites
John2189 453 #3 Posted May 31, 2023 Its an 8 speed 1 Share this post Link to post Share on other sites
c-series don 8,708 #4 Posted May 31, 2023 I think that was asked because the earlier models had a Sunstrand transmission and the newer ones had an Eaton Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,046 #5 Posted June 1, 2023 You are correct on the years produced. Check the pto switch - 1980-81 4 wires, 1984 2 wires 2 Share this post Link to post Share on other sites
John2189 453 #6 Posted June 1, 2023 47 minutes ago, gwest_ca said: You are correct on the years produced. Check the pto switch - 1980-81 4 wires, 1984 2 wires It doesn’t have an electric pto 1 Share this post Link to post Share on other sites
Pullstart 62,905 #7 Posted June 1, 2023 7 hours ago, John2189 said: It doesn’t have an electric pto Safety switch… Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,046 #8 Posted June 1, 2023 The pto switch is in the starter circuit. Pto must be off for the starter to work. 1 Share this post Link to post Share on other sites
John2189 453 #9 Posted June 1, 2023 30 minutes ago, gwest_ca said: The pto switch is in the starter circuit. Pto must be off for the starter to work. Oh ok I didn’t know it had one. I’ll check it out this afternoon. I assume it would be at the pto lever 1 Share this post Link to post Share on other sites
John2189 453 #10 Posted June 2, 2023 Ok if this is the right switch, it only has one wire going to it. IMG_3092.mov 1 Share this post Link to post Share on other sites
