D_Mac 9,156 #51 Posted June 10, 2023 At the end of the line on the 310-8. Cleaned the screen in the tank, pulled fuel line at fuel pump, it is pumping gas. Fresh ethanol free gas in tank. Fuel flow is good. When engine cranks over I notice it spits gas from barrel of carb. Still won't start. Need help from you experts as I have no other ideas. Calling out for help.!!!! SOS !! Share this post Link to post Share on other sites
Wheelhorse#1 1,761 #52 Posted June 19, 2023 On 6/10/2023 at 5:46 PM, D_Mac said: At the end of the line on the 310-8. Cleaned the screen in the tank, pulled fuel line at fuel pump, it is pumping gas. Fresh ethanol free gas in tank. Fuel flow is good. When engine cranks over I notice it spits gas from barrel of carb. Still won't start. Pull the spark plug and see if its wet, maybe fouled .Sounds like you're getting too much fuel, flooding out. Take the bowl apart and check the float isn't stuck. Share this post Link to post Share on other sites
ebinmaine 70,804 #54 Posted June 20, 2023 On 5/31/2023 at 2:36 PM, ebinmaine said: Either do that or send me the ORIGINAL carb. I'll rebuild it and send it back to you. After multiple sessions in the ultrasonic cleaner this one's ready to go. 2 2 Share this post Link to post Share on other sites
cleat 7,032 #55 Posted June 21, 2023 On 6/19/2023 at 7:16 AM, Wheelhorse#1 said: Pull the spark plug and see if its wet, maybe fouled .Sounds like you're getting too much fuel, flooding out. Take the bowl apart and check the float isn't stuck. I have had bad plugs that would only fire a really rich mixture making you think carb was bad. 2 Share this post Link to post Share on other sites
Wheelhorse#1 1,761 #56 Posted June 21, 2023 On 5/31/2023 at 2:36 PM, ebinmaine said: Agreed. Either do that or send me the ORIGINAL carb. I'll rebuild it and send it back to you. I've had 4 big block Kohler engines with 4 cheap carbs and all 4 were junk. The isavetractors carb John bought for the backhoe before I got it is working fine. Ill agree.Those IST carbs are some of the same available on flabby bay and the jungle store.Their just not quite the same as original OEM carbs. 1 Share this post Link to post Share on other sites
ebinmaine 70,804 #57 Posted June 21, 2023 1 hour ago, cleat said: I have had bad plugs that would only fire a really rich mixture making you think carb was bad. Seconded 1 Share this post Link to post Share on other sites
pfrederi 18,339 #58 Posted June 24, 2023 On 6/20/2023 at 7:30 PM, ebinmaine said: After multiple sessions in the ultrasonic cleaner this one's ready to go. Eric what do you use fro solvent/cleaning agent in the ultra sonic cleaner. i used purple power but it seriously discolored the carb body and every time you touched it you got gray on your fingers. 2 Share this post Link to post Share on other sites
ebinmaine 70,804 #59 Posted June 24, 2023 11 minutes ago, pfrederi said: Eric what do you use fro solvent/cleaning agent in the ultra sonic cleaner. i used purple power but it seriously discolored the carb body and every time you touched it you got gray on your fingers. I tried using a product called Incredible Pink. That worked well but left the film you speak of. The pics above are when I used gasoline. I found that to be a good solution. 1 Share this post Link to post Share on other sites
HyperPete 540 #60 Posted July 8, 2023 My $0.02: Purple power is strongly alkaline and should not be used on aluminum. Gas has a low flashpoint and terrible fumes. I like mineral spirits. Much higher flashpoint, very little odor, and works just about as well as gasoline. 1 Share this post Link to post Share on other sites
