cafoose 3,360 #1 Posted May 27, 2023 I just got done mowing three to four foot tall grass with my 520-HC. I'm really impressed how it cut right through and the governor hardly kicked in 4 4 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,498 #2 Posted May 27, 2023 WOW. me to. 1 1 Share this post Link to post Share on other sites
cafoose 3,360 #3 Posted May 27, 2023 Just now, JERSEYHAWG / Glenn said: WOW. me to. I did have to go over it several times to get it to look that good but it was more seat time 5 Share this post Link to post Share on other sites
JCM 9,923 #4 Posted May 27, 2023 Tough to beat a well running 520. 1 1 Share this post Link to post Share on other sites
Pullstart 63,544 #5 Posted May 28, 2023 What deck? 1 Share this post Link to post Share on other sites
cafoose 3,360 #6 Posted May 28, 2023 3 minutes ago, Pullstart said: What deck? 48" side discharge standard issue for 1988 520-HC. Just put a NOS PTO belt and PTO clutch on it. I only heard a little belt squeal once or twice. Could have been deck belt squeal. I never investigated it. 3 Share this post Link to post Share on other sites
oldlineman 1,489 #7 Posted May 28, 2023 IMPRESSIVE 2 1 Share this post Link to post Share on other sites
lynnmor 7,482 #8 Posted May 28, 2023 The 520-H tractors have a horsepower meter which is actually a vacuum gauge. You would be surprised at how much that meter is in the 75% to 100% range meaning that the governor has the carburetor nearly or fully open. If I were mowing grass that high it would be near 100% all the time. 1 1 Share this post Link to post Share on other sites
Handy Don 13,087 #9 Posted May 28, 2023 32 minutes ago, lynnmor said: The 520-H tractors have a horsepower meter which is actually a vacuum gauge. You would be surprised at how much that meter is in the 75% to 100% range meaning that the governor has the carburetor nearly or fully open. If I were mowing grass that high it would be near 100% all the time. Out of curiosity, do you have any idea of the vacuum range of that gauge in inches of mercury or other scale? Thanks! 1 Share this post Link to post Share on other sites
cafoose 3,360 #10 Posted May 28, 2023 2 hours ago, lynnmor said: The 520-H tractors have a horsepower meter which is actually a vacuum gauge. You would be surprised at how much that meter is in the 75% to 100% range meaning that the governor has the carburetor nearly or fully open. If I were mowing grass that high it would be near 100% all the time. I never realized that. I knew of the gauge but didn't think to look at it. I was going by sound of the engine and it seldom grunted 1 Share this post Link to post Share on other sites
Brockport Bill 1,778 #11 Posted May 28, 2023 wow -- the HC is certainly a beast 3 2 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,498 #12 Posted May 28, 2023 No doubt it is. Luv the sound of its motor to. Like no other. 3 1 Share this post Link to post Share on other sites
lynnmor 7,482 #13 Posted May 28, 2023 4 hours ago, Handy Don said: Out of curiosity, do you have any idea of the vacuum range of that gauge in inches of mercury or other scale? Thanks! I have never compared the gauge to one that has numbers. I do know that 100% horsepower equates to zero vacuum. I would think that it is the typical -30 to 0 with a different dial. 1 Share this post Link to post Share on other sites
Handy Don 13,087 #14 Posted May 28, 2023 2 hours ago, lynnmor said: I have never compared the gauge to one that has numbers. I do know that 100% horsepower equates to zero vacuum. I would think that it is the typical -30 to 0 with a different dial. The P218 that I’m running has the tube for the vacuum (plugged at the moment due to the usual broken sensor). I’ve considered hooking it to a vacuum gauge from a 520. Maybe I’ll find one at the Show to experiment with. 1 Share this post Link to post Share on other sites
lynnmor 7,482 #15 Posted May 28, 2023 There is an air filter sensor that often breaks, the tube to it connected to the bottom of the air filter base. The horsepower gauge connected to a fitting threaded into the intake manifold forward of the carburetor. The intakes usually aren’t drilled on models without the horsepower gauge. 1 Share this post Link to post Share on other sites
Handy Don 13,087 #16 Posted May 29, 2023 15 minutes ago, lynnmor said: There is an air filter sensor that often breaks, the tube to it connected to the bottom of the air filter base. The horsepower gauge connected to a fitting threaded into the intake manifold forward of the carburetor. The intakes usually aren’t drilled on models without the horsepower gauge. Thanks, that makes perfect sense. I’ll have to check my manifold. I do seem to recall an un-drilled boss in the manifold casting, where the fitting likely would connect, and wondered about it. If I ever have it off, I’ll consider drilling and tapping for.a fitting! 1 Share this post Link to post Share on other sites
lynnmor 7,482 #17 Posted May 29, 2023 7 minutes ago, Handy Don said: Thanks, that makes perfect sense. I’ll have to check my manifold. I do seem to recall an un-drilled boss in the manifold casting, where the fitting likely would connect, and wondered about it. If I ever have it off, I’ll consider drilling and tapping for.a fitting! You may not have a boss but if you do you are ahead of the game. 1 Share this post Link to post Share on other sites
2drxploder 123 #18 Posted May 29, 2023 i know the C is for commercial, but what are some of differences compared to the standard 520h? 1 Share this post Link to post Share on other sites
Brockport Bill 1,778 #19 Posted May 29, 2023 per the WH brochure -- HC faster top forward and reverse speed - longer wheel base - longer tractor - wider - heavier - bigger front and rear tires - 1 Share this post Link to post Share on other sites
Wheel-N-It 2,969 #20 Posted May 29, 2023 That was very impressive !! I've never owned a 520, but you're making me want to look into it. 2 Share this post Link to post Share on other sites
lynnmor 7,482 #21 Posted May 29, 2023 10 hours ago, Brockport Bill said: per the WH brochure -- HC faster top forward and reverse speed - longer wheel base - longer tractor - wider - heavier - bigger front and rear tires - It also has a larger air filter, no useless hood louvers and less fancy trim. Share this post Link to post Share on other sites
Handy Don 13,087 #22 Posted May 29, 2023 33 minutes ago, lynnmor said: It also has a larger air filter, no useless hood louvers and less fancy trim. 11 hours ago, Brockport Bill said: per the WH brochure -- HC faster top forward and reverse speed - longer wheel base - longer tractor - wider - heavier - bigger front and rear tires - Most of the “HC” features wound up being part of the later stock 520-H’s. Swept axle (including stronger, adjustable tie rods), 1” spindles with thrust bearings, tapered front wheel bearings, and gear reduction steering (two full turns lock-to-lock instead of one full turn). What didn’t? The non-louver hood, the oversize air cleaner, and the faster final drive gearing (sigh)! Share this post Link to post Share on other sites
