Bob Bauer 27 #1 Posted May 27, 2023 (edited) Good afternoon, I have a question about my rj-58 with a 5003 transmission,are the shift forks the same in a 8 speed transmission? I have a part number for my rj 58 #3503 and I found the same number in a 8 speed transmission and wondering if it will fit ? Thanks Edited May 27, 2023 by Bob Bauer Share this post Link to post Share on other sites
stevasaurus 22,995 #2 Posted May 27, 2023 With out actually looking at the parts manual...if you have the same part number for a part, it will fit. Wheel Horse manual transmissions kept a lot of the same parts for the evolution of their transmissions. Bearings, cluster gears, pinions, gaskets and other parts are common to the different transmissions. If you look a any parts list for a certain trans, and the parts list for another trans has the same part number...it fits. Know this...when Wheel Horse changed ownership through the years...they may have changed some part numbers, but that will usually have a (used to be) number to check it by. Hope that helps. Share this post Link to post Share on other sites
Bob Bauer 27 #3 Posted May 27, 2023 (edited) 45 minutes ago, stevasaurus said: With out actually looking at the parts manual...if you have the same part number for a part, it will fit. Wheel Horse manual transmissions kept a lot of the same parts for the evolution of their transmissions. Bearings, cluster gears, pinions, gaskets and other parts are common to the different transmissions. If you look a any parts list for a certain trans, and the parts list for another trans has the same part number...it fits. Know this...when Wheel Horse changed ownership through the years...they may have changed some part numbers, but that will usually have a (used to be) number to check it by. Hope that helps. Yes in my parts manual the parts # is 3503 and the same # I found is the same but it’s out of a 8 speed. The shafts are different but the shift forks look the same.thanks Edited May 27, 2023 by Bob Bauer Share this post Link to post Share on other sites
oliver2-44 10,144 #4 Posted May 28, 2023 6 hours ago, Bob Bauer said: The shafts are different but the shift forks look the same.thanks If by different you see a “flat” on the shafts, they will work. Wheelhorse added the flat to the shafts to eliminate a suction problem. 1 Share this post Link to post Share on other sites
Bob Bauer 27 #5 Posted May 28, 2023 (edited) 16 hours ago, oliver2-44 said: If by different you see a “flat” on the shafts, they will work. Wheelhorse added the flat to the shafts to eliminate a suction problem. I’m not sure what you mean by flat but on the ones I have now there are three notches on each shaft on the ones I’m looking at the notches or should I say grooves go all the way around the shaft. Edited May 28, 2023 by Bob Bauer Share this post Link to post Share on other sites
Pullstart 63,837 #6 Posted May 28, 2023 53 minutes ago, Bob Bauer said: I’m not sure what you mean by flat but on the ones I have now there are three notches on each shaft on the ones I’m looking at the notches or should I say grooves go all the way around the shaft. The grooves ended up being cut deeper. The detent pin may need to be replaced as well by a longer one. It was a solid fix to prevent hanging up the transmission in two gears. Share this post Link to post Share on other sites
Bob Bauer 27 #7 Posted May 29, 2023 3 hours ago, Pullstart said: The grooves ended up being cut deeper. The detent pin may need to be replaced as well by a longer one. It was a solid fix to prevent hanging up the transmission in two gears. Ok thanks for your help. Share this post Link to post Share on other sites
