Stigian 1,234 #301 Posted December 24, 2011 Ian, Great looking tranny, cant wait for the posting! Cheers and Happy Christmas and Boxing Day! Don V Thanks Don, yeah the trans does look quite good, nice clean oil in it as well. You have a good "silly season" as well I didn't take many photos of the master cylinder frame in construction but I did manage a few. Those with a good long term memory might remember this frame from my 1st and oversized attempt at this 6x6 build lark. It was the frame I built to hold the cooling radiator up! Knew those lengths of box would come in handy some day Throw in a strange shape bit of steel about to be cut from this dash remains.. And a couple of levers.. Ta-Daa a couple of mounted cylinders That's all for now Chaps more to come later if time permits, I'm being called from the pc to do the "seasonal thing" :rolleyes: Share this post Link to post Share on other sites
Jake Kuhn 1,579 #302 Posted December 24, 2011 Looking good! :handgestures-thumbup: Share this post Link to post Share on other sites
Rollerman 290 #303 Posted December 24, 2011 Thanks for the update Ian, allways good to see new updates & also to see your 6x6 is getting closer to moveing under it's own power. Share this post Link to post Share on other sites
AMC RULES 37,144 #304 Posted December 24, 2011 Ahh Ian, always worrying about the aesthetics. Looks even more amazing with every update. Share this post Link to post Share on other sites
Don1977 604 #305 Posted December 25, 2011 Thanks for the update! Stigian I still haven't got an engine for my project. Share this post Link to post Share on other sites
Stigian 1,234 #306 Posted December 25, 2011 Looking good! Thanks Jake. Thanks for the update Ian, allways good to see new updates & also to see your 6x6 is getting closer to moveing under it's own power. Ta-muchly Stephen Yeah it's getting there slowly, almost got the steering brakes sorted now, it will be good to move on to another part of the build. Ahh Ian, always worrying about the aesthetics. Looks even more amazing with every update. Thanks Craig, it just made sense to change the stoppers while the other ones were off. Thanks for the update! Stigian I still haven't got an engine for my project. Your welcome Don, in fact have another update I'm sure an engine will turn up for your project, just keep looking So having got the cylinders mounted I pulled it apart again so I could clean up cylinder mounting frame and give it a quick protective coating of paint. Having run out of aerosol red oxide it got a nice coating of Fiat metallic blue! Once dry it got bolted back in. These slider brake lever thingys need stoppers inside not only to stop them being pulled out to far (should over braking "Panicing" happen) but also to stop the slider rod things from turning. To get the correct measurements on the rods meant plumbing the brakes in one side and getting a bit of pressure in them. So off came the top to get easy access to the rear of the cylinders. This also gives me a chance to work out the pipe routing. Plenty of space to run the brake pipes Outside the frame running down inside the hood stand worked the best. Down the the splitter mounted below "foot level". And off to the calipers. Bleeding all the air out of an empty brake system took ages but got there in the end. Now the hard part... Trying to drill and tap a hole into the side of a hardened axle!! So hard in fact that my drill bits would not touch it, even clamping it in the lathe and attacking it will a milling bit only produced a small mark!! Hhmm... A coffee, a smoke and a bit of thinking was needed.. As these sliders need to be removable I can't weld the stoppers on, I can't drill through the side of it, and the only place I can bolt anything onto them is where the adjusters are!! So there I was, coffee in hand leaning on the bench vice looking at the problem and looking at the key ways that were already cut in the axles sliders.. Hhmmm... I feel a solution coming on..... But your going to have to wait a little while, I need to get dinner cooking... Share this post Link to post Share on other sites
varosd 1,185 #307 Posted December 25, 2011 Ian, It's almost like a old 1940's movie cliffhanger as we await the solution/update to a setback/conundrum that you encounter! Great editing in regards to the photos! Will this beast make it through the door? Share this post Link to post Share on other sites
Stigian 1,234 #308 Posted December 25, 2011 Ian, It's almost like a old 1940's movie cliffhanger as we await the solution/update to a setback/conundrum that you encounter! Great editing in regards to the photos! Will this beast make it through the door? Lol, I know I'm "old in my ways" (well that's what my Wife keeps telling me) but I didn't think I stretched all the way back to the 40's Yep the beast will fit through the door, it has done already during the summer in rolling chassis form. It's got a little longer since then but no wider. The solution came in the form of the remains of a front wheel.. Or to be a tad more accurate these strange bush thingys that came out the wheel.. And Yippie a quick test drill showed I could drill into them One flange trimmed off. A bit of very careful slot cutting and a bit of key steel slots in a treat it just needs welding up With the key welded in a large washer needed to be welded on. Welded..... Ok, maybe not the tidiest of welding but welded.. A view from the inside. And finally bolted on the end of the slider thingy.. It won't turn on the shaft and I can drill into it to make the stopper guide thingys.. A lot of farting about because I couldn't drill one hole, but sometimes the extra work has to be done. And that chaps is this build thread up to date :thumbs: Share this post Link to post Share on other sites
varosd 1,185 #309 Posted December 25, 2011 Yep the beast will fit through the door, it has done already during the summer in rolling chassis form. It's got a little longer since then but no wider. But instead of cutting a hole in the wall, perhaps you might have to "add onto" the workshop! I can't wait until final fireup and you have to get " in action" pictures ...how property are you on? Share this post Link to post Share on other sites
massey 119 #310 Posted December 25, 2011 Looking good Ian, looking good. Share this post Link to post Share on other sites
Stigian 1,234 #311 Posted December 27, 2011 Yep the beast will fit through the door, it has done already during the summer in rolling chassis form. It's got a little longer since then but no wider. But instead of cutting a hole in the wall, perhaps you might have to "add onto" the workshop! I can't wait until final fireup and you have to get " in action" pictures ...how property are you on? I'd love to "add onto" the workshop, I'm not sure my landlord would be so keen though, it was a hell of a battle to get them to agree to me building a workshack in the first place!!! The first fire-up and drive will be a sweet moment, can't wait for that day Looking good Ian, looking good. Thanks Massey, it's not up to the standards of your fine tracked beast, it's more of a "rough and ready" kinda looking good. Righto chap's it's time for a small update. Having spent a lot of time farting about making a couple thingys I could drill into for the ends of the sliders, I drilled and taped them. My metal stash is getting a bit low at the mo, so rather than cutting up my last bit of angle (which is coming in handy for all sorts of clamping uses at the mo), I cut up some box to make some more angle. This should give you an idea on how I plan to stop the sliders rotating, the grey steel just needs a couple of slots cut in to it. A bit of clamping for welding action. One slot done. The idea is I will find something that's slightly faster wearing than the steel to make the er.. upright spacer thingys (The bit between the 2 washers). so I can just replace them when they wear and not the slots. Two done and bolted down, just a bit of finishing work to do. Having done that bit of finishing work there was really only one (well two of them) part left to build for the brake steering system..... Yep the control levers Starting with four bits of bar... Throw in a couple of longer bits of bar, a tad of welding and thus I had created a pair of motorcycle bars!.... Er...... Best try again That looks better.. And to finish this update, a tantalizing glimpse of what one of the steering levers will look like in place.. They will need a little trimming in height but I can't tell by how much until I'm able to plonk a seat on the machine and sit with the levers in my hands.. The ceiling a a little too low for that at the mo Share this post Link to post Share on other sites
Ole MN 11 #312 Posted December 27, 2011 Ian, Lets hope in the new year, the fabircating gods will continue to be on your side. I have mixed feelings about your finshing this build. As I enjoy following this and your great commentary. As always thanks for the update. Share this post Link to post Share on other sites
Stigian 1,234 #313 Posted December 30, 2011 Ian, Lets hope in the new year, the fabircating gods will continue to be on your side. I have mixed feelings about your finshing this build. As I enjoy following this and your great commentary. As always thanks for the update. Hi Brad, you don't have to worry about this build finishing any time soon, lot's of work to do on it yet plus a house move sometime in the next 6 months will slow the build down a bit. Another small update for you chap's, the first steering lever thingy tack welded on. The second lever needed a slight sliver slicing off, quite proud of this cut Rob taking the bench for a test drive Ta-Daa now with steering... Well almost.. That vintage look... And after a clean up of the welds and a splash of protective paint.. Don't worry, they won't be staying blue. And that is about all I can do on the brake steering system until I get a couple of matching brake fluid reservoirs and another brake hose.. So the time had come to make a start on a job I've been putting off.... Making a drive pulley for the engine!!! The lathe work is cool, I'm quite looking forward to a bit of relaxing sitting at the lathe time... It's the cutting of a square from this slab I wasn't looking forward too.... Not being able to put the job off any longer out came the grinder for a long days cutting. Half way through one side.. Joining the cuts from each side the old fashioned way!! Lot's of cursing and creaking of back at this stage!! With the aid of a big hammer off the square came off. To celebrate getting a horrible job done I made a coffee And then cut the corners off the square, leaving it ready to go on the lathe.. Share this post Link to post Share on other sites
AMC RULES 37,144 #314 Posted December 30, 2011 Such Hurculean efforts! Nothing short of an inspiration you are Ian. Living proof, where there's a will, there is a way. :flags-wavegreatbritain: Share this post Link to post Share on other sites
meadowfield 2,650 #315 Posted December 30, 2011 Such Hurculean efforts! Nothing short of an inspiration you are Ian. Living proof, where there's a will, there is a way. similar to what I was thinking.... "where there's a wheel horse, there is a nutcase cleaning/painting/welding/turning/polishing/pulling/pushing/ploughing" * Awesome work still Ian, I'm almost in my new workshop - so I'll be able to curb my jealousy and join the nutcase fraternity mark *tick as applicable Share this post Link to post Share on other sites
massey 119 #316 Posted December 30, 2011 Sorry to hear this will need to be put on hold as you move again Ian. I always enjoy your updates and and commentary and the b/w photo is a nice touch. I'm liking those levers. Share this post Link to post Share on other sites
shootinok 15 #317 Posted December 31, 2011 Oh, how I wish for those fabrication skills you have.... enough to make a grown man cry :) Share this post Link to post Share on other sites
zieg72 209 #318 Posted December 31, 2011 All I can say is well done so far... And to do it all with that with that horrible condition that effects your mobility. To all who haven't viewed his YouTube updates I encourage you to sign up and see them. I am impressed with Ian's accomplishments and his wonderful outlook and attitude. Share this post Link to post Share on other sites
Kelly 1,030 #319 Posted January 1, 2012 I really enjoy reading your threads, I wait a week or two before reading them, that way I have a bit to read and get right into it, then I'm at the end, wanting more. Share this post Link to post Share on other sites
JimD 3,345 #320 Posted January 8, 2012 Ian, I always enjoy your updates to this build. Understanding more about the effort required by you to do what you have done here truly humbles me. You are an inspiration to me. Thank you. Share this post Link to post Share on other sites
massey 119 #321 Posted January 8, 2012 Looking forward to your next update also Ian but take your time there, we'll still be here. Hope all is well. Share this post Link to post Share on other sites
Stigian 1,234 #322 Posted January 17, 2012 Such Hurculean efforts! Nothing short of an inspiration you are Ian. Living proof, where there's a will, there is a way. Thanks Craig, if I'm inspiring people to have "a go" at building something or trying new things then I'm very cool with that. Don't be scared folks, have a go similar to what I was thinking.... "where there's a wheel horse, there is a nutcase cleaning/painting/welding/turning/polishing/pulling/pushing/ploughing" * Awesome work still Ian, I'm almost in my new workshop - so I'll be able to curb my jealousy and join the nutcase fraternity mark *tick as applicable Cheers Mark. That's good news about your workshop, I bet you can't wait to get cracking on with a mad project. Sorry to hear this will need to be put on hold as you move again Ian. I always enjoy your updates and and commentary and the b/w photo is a nice touch. I'm liking those levers. Another house move has kinda been on the cards for a while, we don't want to move again but this place is costing stupid amounts each month!! Glad you enjoy my undates, your crawler project makes for a really good read That photo was taken with black and white in mind, think I must of been sqwinting or looking through smoke at the time! The levers still need a bit of work to get them sitting right, but I do have a plan for sorting them out. Oh, how I wish for those fabrication skills you have.... enough to make a grown man cry Lol, I'm self taught at this fabrication marlarkry.. You could be too... Give it a whirl!! Oh, too much crying make your Wh's rust All I can say is well done so far... And to do it all with that with that horrible condition that effects your mobility. To all who haven't viewed his YouTube updates I encourage you to sign up and see them. I am impressed with Ian's accomplishments and his wonderful outlook and attitude. Very kind words Zieg, thank you.. Yes the Dystonia can be a right pain.. (well, everywhere at times as the constant shaking is wearing all my joints out) at times. but battle through it I must. My outlook and attitude is down to one thing.. Choice. Once I'd got the "all upset about it/what is happening to me?" bit out the way, I decided I had three choices about what I could do with my life.. 1 - Sit in front of the TV all day and slowly turn into a vegtable... 2 - Climb into a bottle... 3 - Stick 2 fingers (sometimes 3 or 4 if my hands are not doing what I'm asking them to) up at the Dystonia and do something that keeps me active and my brain working.. Number one is out as sitting for too long kills my back, day time TV is rubbish, and I've never been one for sitting about doing nothing anyway.. Number two is out as I did the "drinking way way to much thing" years ago and it's not somewhere I'm keen to return to.... I'm too old for hang overs which I've never enjoyed anyway.. Which for me (and for everyone else I hope) leaves only one option... A fun creative way of spending my time. I really enjoy reading your threads, I wait a week or two before reading them, that way I have a bit to read and get right into it, then I'm at the end, wanting more. Hey Kelly, your week or two waiting is nearly up, quite a big update coming up.. Ian, I always enjoy your updates to this build. Understanding more about the effort required by you to do what you have done here truly humbles me. You are an inspiration to me. Thank you. Thank you Jim, sometimes the "effort" is a bit hard to muster up, but the enthusiasm is never lacking. I feel humbled that I have inspired you.. Thank you. Oh, I've not forgotten about a reply to your PM, it will get to you. Looking forward to your next update also Ian but take your time there, we'll still be here. Hope all is well. Ta-muchly Massey, the next update is here. I've been a bit quiet partly due to feeling a bit rough, and partly because all the lathe work I have been doing has been very slow it wouldn't of made for much of an update. Almost ready for an update now, but first... I can't believe this thread has had over 20000 views!!!! I am truly humbled that you all enjoy reading this thread so much.. Thanks Guy's, it means a lot to me :thumbs: Share this post Link to post Share on other sites
Stigian 1,234 #323 Posted January 17, 2012 At the end of my last update I left you with a square-ish slab of steel with the corners cut off, time to get it on the lathe.. First up is a bit of "whirly hole drilling" action.. Followed by facing off one side and rounding off some corners. One side looking a whole lot more circular. Time to make that hole a bit bigger. You can also see that flat face is no longer flat any more. This is the side the PTO clutch plate will bolt onto, the 71 Raider clutch plate I am thinking of using has the friction material held on with rivets, the recess is to give space for the back of the rivets allowing the clutch plate to sit flat on the pulley. One side of beauty.. One side of ugly!! But not ugly for long.. That looks better A quick trial fit.. It's not as big as the photo makes it look! Time to get "in the groove" man!! A bit at a time.. Having a KT-17 engine with a hydro size pulley on the bench came in handy for taking measurments Almost done groovin' And finishing off with a little bit of weight loss on the PTO side of the pulley. Old and new together.. To celebrate finishing the pulley I filled the Workshack up with sepia coloured steam while making a coffee While my cup of coffine was cooling the new pulley was put on the engine just to see how it looked.. And then given a quick coat of blue paint to help keep the rust away.. Share this post Link to post Share on other sites
Stigian 1,234 #324 Posted January 17, 2012 Having spent what felt like years standing in front of the lathe I though I'd have a break and have a play with the engine. To get the engine sitting in the right place the exhaust and air cleaner had to come off.. Had a bit of a close call with a washer jumping down the exhaust port, luckly it came back out easy.... Phew!! A trial fit of the KT-17s air cleaner, it's a bit too bit to fit under the hood though.. Can you guess where one of the exhaust bolts ended up? With the M20's air cleaner off I could get a good look at the carb, both the choke and throttle butterflys are stuck but I'd expect that kind of problem from an engine thats not been started in quite a while. A view from one side with the engine in almost the right place. And a view from the other side with pulley and PTO bit propped up. Do you think this Raider air cleaner will be able to flow enough air into this 20hp engine if I add a "KT-17 air cleaner style induction pipe" thingy? It was roughly at this point where I noticed a slightly er... big problem with mounting the engine where I want to... Look at the what I would have to drill through!! Also with the belt guard placed roughly in place it looks like the engine needs to be raised a bit! So what I need is a steel plate that will bolt to the base of the M20 lump that can in turn be bolted down to the chassis.. And if it would raised the engine height a bit that would be perfect.. Que the KT-17 engine again... Which used to be rubber mounted when it was was in it's original home which happened to be a C-175 Would you look at the mess!! With all that oiley gunk scrapped off A M18 case got plonked on the plate to see if the mounting holes lined up.. Thought they might and they did. Some elbow grease later and what a transfomation.. Who would of thought there would be such good paint hiding under all that gunk!! That's all for now folk's, There is loads more to come but I'm having trouble keeping my eyes open now... Time for some "shut-eye" me thinks. Night night.. Share this post Link to post Share on other sites
can whlvr 993 #325 Posted January 18, 2012 well ian she sure is coming along,i got to hand it to ya making your own pulley is devoted,thats quite a slab of steel you have there,and i like how you use the lathe instead of buying things,really a great build you got going here Share this post Link to post Share on other sites
