COMMANDO6 20 #726 Posted August 14, 2012 Once you get it apart get the voltage and size of them and you can order some brand new ones from http://www.mouser.com/ Share this post Link to post Share on other sites
Staub'sLawnmower 10 #727 Posted August 15, 2012 Check the start switch and the cap. Thay always like to go down! Share this post Link to post Share on other sites
Stigian 1,234 #728 Posted August 22, 2012 On 8/11/2012 at 3:00 PM, massey said: Looking good Ian, I like the chain drive idea. Thanks Massey, the chains should do the trick. On 8/11/2012 at 4:12 PM, bowtiebutler956 said: Looking good Ian! Best use of skateboard wheels I've ever seen. Matt It was a tip I was given by the 2012 world mower racing champion If the skateboard wheels handle "racer" abuse then they should be up to the job on my beast. On 8/11/2012 at 7:21 PM, 312Hydro said: Check the starting capacitor on the compressor motor. It's probably bad. On 8/12/2012 at 11:57 AM, COMMANDO6 said: I don't know how old the compressor is, but capacitors tend to die with age. Thanks Guy's, I still need to crack the "electricary" box that sits on top of the motor to check the capacitor, but a quick look on Fleabay showed me how cheap they are to buy Age of compressor...Er.... maybe about 4 years On 8/12/2012 at 7:36 PM, meadowfield said: Yeah, motor run caps.... They hate long mains runs ( high inductance makes them work harder) I've seen your mains routing. Morning Dude, yep my mains routing is Er... Not quite the best set-up.. I'd like to do a proper job, but out landlord won't have it!! On 8/13/2012 at 5:50 AM, dbartlett1958 said: I don't know what HP your compressor motor is, but you can wire in a large wattage light bulb(300Watt heat lamp bulb works good) in place of the capacitor to diagnose if you happen to have one about. Thanks for that tip David, I've no idea what HP the motor is. I will have a look when I delve under the bench to pull out the capacitor. Share this post Link to post Share on other sites
Stigian 1,234 #729 Posted August 22, 2012 On 8/14/2012 at 1:09 PM, COMMANDO6 said: Once you get it apart get the voltage and size of them and you can order some brand new ones from http://www.mouser.com/ Ta muchly On 8/15/2012 at 11:00 AM, Staub said: Check the start switch and the cap. Thay always like to go down! I'm guessing the switch is still working as "something" makes a loud buzz sort of sound when I turn it on, so the cap it must be. Much to my shame I've not done anything on this project for quite a few days, but I did find time yesterday to have a look at how the drive chains would run in the outriggers.. I've still not got any 1/2 chain links so a bit of phone cable had to do. If I could take out one chain link then life would so so much easier. But as I can't, and can't move the axles a 1/2 link is needed.. I was quite amazed at how much "slack" just a 1/2 link produces! Which means I now need 2 chain guides/rollers per chain to deal with the slack.. One up top.. And one below.. And that chaps is all that has been happening!! The good news is I will have some money again on Friday, so I can order that last bits needed for this chain conversion... Yep... Test drive 3 should be under 2 weeks away :D 1 Share this post Link to post Share on other sites
Don1977 604 #730 Posted August 22, 2012 Glad to hear that you will be trying that machine out again in a couple of weeks. We will be waiting for the video. Share this post Link to post Share on other sites
Stigian 1,234 #731 Posted August 26, 2012 Thanks Don, fingers crossed for a couple of weeks but no guarantees at the mo.. I have been having a bit of fun at the lathe for a couple of days... The time had come to sort out the engine pulley I made. Quite what happened to my measuring when I made it I don't know, but somehow the groove ended up a lot smaller than it should of been! The belt won't quite fit! Yep.. That's a lot smaller than it should be! Best bung it in the lathe then... Hhmmm.. That doesn't look that well held to me. Normally for a hole this size I would use the drill chuck in the tail stock to hold bits steady.. This time the chuck was too small... Time for a bit of this So what I need is a bit version of one of these.. Which can be made out of this. Some interesting tool setting up later. Part way through the narrow taper. Ta-Daa, the finished article. So after all that work did it fit and did the pulley spin true?? Yep Pulley taken out to the correct size... For some reason my camera wouldn't focus too well on it, so sorry about the naff photo. The belt fits much better now. Well, the belt fit's the pulley quite well.. But as for the length!! The previous belt was a B140 which was a bit short.. So short it would fit under the belt tensioner... So this time I bought the next size up, a B144 which is too big I guess it's time to make this black pulley a lot more adjustable.. But that can wait for another day. In other news, all parts needed to get this beast rolling again have been ordered, fingers crossed they should all be be by Tuesday :handgestures-thumbup: 1 Share this post Link to post Share on other sites
bowtiebutler956 650 #732 Posted August 26, 2012 Belts can be annoying like that. I have a little saying I like to use when I'm fabricating things " I cut it twice, and its still to short"! Nice work Ian, and I really really wish I had a lathe! Matt :flags-texas: Share this post Link to post Share on other sites
Bobie01 22 #733 Posted August 26, 2012 ian you are the man!!!!! Share this post Link to post Share on other sites
Ole MN 11 #734 Posted August 27, 2012 Ian, Thanks again for the update. Keep it moving forward one step at a time. Brad Share this post Link to post Share on other sites
Stigian 1,234 #735 Posted August 29, 2012 On 8/26/2012 at 7:01 PM, bowtiebutler956 said: Belts can be annoying like that. I have a little saying I like to use when I'm fabricating things " I cut it twice, and its still to short"! Nice work Ian, and I really really wish I had a lathe! Matt Hey Matt, nice saying Yep you should get a lathe, they are such a handy bit of kit to have about the place. On 8/26/2012 at 8:06 PM, Bobie01 said: ian you are the man!!!!! Thanks Bobie. On 8/27/2012 at 1:00 AM, Ole MN said: Ian, Thanks again for the update. Keep it moving forward one step at a time. Brad Your welcome Brad, I'm hoping that in a few the beast will not only be able to move forward, but turn as well!! Yesterday I had a look at getting the main drive belt sorted as it's a tad long.. A bigger pulley might do the trick, I thought while looking at the mule drive on my Raider!!! A quick dig under the bench later, a spare was dug out and pulley removed. It looks like it might work.. Ah... Maybe not.. And that's with the pulley on full height adjustment! It would be so much easier to sort the pulley out if the oil filter wasn't in the way.. I guess it had better stay though And then I spotted it hiding in the spares department .. Maybe the solution to the problem?? A C-175 belt tensioner thingy.. A bit of cutting and drilling later, the new brackets were bolted to the engine and the larger mule drive pulley tried.. It would be nice to be able to use this pulley as a bigger diameter puts less strain on the belt when it has to bend back over it's self. It almost worked.. If the belt was half inch longer the tensioner would of gone all the way down as it should, instead the motion lever hit's and won't go into full reverse!! A change of pulley later and the belt is nice and tight and no problems with the motion lever hitting anything.. I just wish the pulley was a little bigger! I was about to take the new belt tensioner thingy off the engine for welding when a large packet arrived.. Yippee more chain.. And the correct size (I managed to order right this time) half links.. A quick test fit of the front left side chain. A previous test fit of the chain using a bit of phone cable instead of a half link showed I needed two chain guides to take up the slack.. With the half link fitted enough slack was taken out the chain only to need one guide! Even stranger, when I test fitted a rear chain I found it didn't need a half link or a guide!!! Quite what is going on I don't know... The axles are the same distance apart.. Even though I knew they were I measured again just to check!! Err.... On the upside it means I don't have to turn any more skateboard wheels on the lathe or drill any more holes in the outriggers :thumbs: 1 Share this post Link to post Share on other sites
bowtiebutler956 650 #736 Posted August 29, 2012 Its looking really good Ian! Matt :flags-texas: Share this post Link to post Share on other sites
Don1977 604 #737 Posted August 29, 2012 Good to see you making some progress on get the 6x6 going. Share this post Link to post Share on other sites
Stigian 1,234 #738 Posted August 29, 2012 On 8/29/2012 at 11:50 AM, bowtiebutler956 said: Its looking really good Ian! Matt Thanks Matt. On 8/29/2012 at 4:06 PM, Don1977 said: Good to see you making some progress on get the 6x6 going. Ta muchly Don. I know it won't be long until test drive time, I'm starting to get butterfly's thinking about it After yesterdays fun and games playing with the drive belt pulley, I decided to start again with it... The small pulley I had fitted really bugged me!!! So after lot's of ing, cutting, drilling and welding I came up with these.. They bolt on like so and even have a small amount of adjustment. Ta-Daa, the bigger mule drive pulley fits. Now without any belt to belt clearance problems Best get on with fitting the chains and sprockets on the right and side then... So off came the outrigger. To have some slots made longer.. One cut later my grinder stopped making a "cutting steel" kinda sound and replaced with with a "motor whirring" sort of noise!! Best crack it open and have a look.. "That's your problem right there"!!.. The beveled gear had decided give up it's grip on the motor spindle.. Which means one dead grinder... Oh well, four years use out of a grinder isn't too bad for me, I do tend to work them quite hard The good news is Pete will be turning up with his grinder tomorrow, so the slots can be cut, outrigger and chains etc bolted on... Then the engine can be fired up and drive bench tested.. 1 Share this post Link to post Share on other sites
Staub'sLawnmower 10 #739 Posted August 29, 2012 It won't be long to you have shop doors open again !!! Look'en good!!! Share this post Link to post Share on other sites
Scrumpy 5 #740 Posted August 30, 2012 Ian, Any chance that you are using chain from two different manufacturers and that it will stretch a bit with use and you will not have any adjuster to take up slack on the second side? Share this post Link to post Share on other sites
meadowfield 2,650 #741 Posted August 30, 2012 On 8/30/2012 at 3:59 PM, Scrumpy said: Ian, Any chance that you are using chain from two different manufacturers and that it will stretch a bit with use and you will not have any adjuster to take up slack on the second side? I was just thinking that ! the chain will definitely stretch during bedding in and use - that few thou' x100 links will add up.... Share this post Link to post Share on other sites
SousaKerry 502 #742 Posted August 30, 2012 Ian, Unless you are buying good quality pre-stretched chain it's a good bet you will be taking out that half link after a few hours of operation, keep it well lubed and count on it stretching a good bit as it wears. Wow what's the chjances of three of us posting about the same thing at the same time :scared-eek: Share this post Link to post Share on other sites
Don1977 604 #743 Posted August 30, 2012 There is a lot of difference between Chinese chain and Morse or Belt Link. Don't know if they make roller chain now. I used to get to get the left over pieces when the shop replaced roller chain in the mill. They would always take a foot or so more than needed. I would get it and put the pieces back together. Share this post Link to post Share on other sites
meadowfield 2,650 #744 Posted September 3, 2012 Ian, c'mon with this update.... I know the answer... just waiting for the pics and video !!!!! Share this post Link to post Share on other sites
312Hydro 474 #745 Posted September 3, 2012 :text-yeahthat: :wwp: Share this post Link to post Share on other sites
COMMANDO6 20 #746 Posted September 3, 2012 the suspense is killing me! We need video! Share this post Link to post Share on other sites
Stigian 1,234 #747 Posted September 3, 2012 On 8/29/2012 at 9:27 PM, Staub said: It won't be long to you have shop doors open again !!! Look'en good!!! Thank you Sir.. Yep it er... won't be long now On 8/30/2012 at 3:59 PM, Scrumpy said: Ian, Any chance that you are using chain from two different manufacturers and that it will stretch a bit with use and you will not have any adjuster to take up slack on the second side? Nope, same chain from the same manufacturers. Same Ebay seller as well. On 8/30/2012 at 4:08 PM, meadowfield said: On 8/30/2012 at 3:59 PM, Scrumpy said: Ian, Any chance that you are using chain from two different manufacturers and that it will stretch a bit with use and you will not have any adjuster to take up slack on the second side? I was just thinking that ! the chain will definitely stretch during bedding in and use - that few thou' x100 links will add up.... Howdo Mark, your right about the chains stretching a bit On 8/30/2012 at 4:13 PM, Sousakerry2 said: Ian, Unless you are buying good quality pre-stretched chain it's a good bet you will be taking out that half link after a few hours of operation, keep it well lubed and count on it stretching a good bit as it wears. Wow what's the chances of three of us posting about the same thing at the same time Good quality chain is a bit out of my budget, it's more like, ok quality non pre stretched chain.. You may be right about taking the half links out. On 8/30/2012 at 9:08 PM, Don1977 said: There is a lot of difference between Chinese chain and Morse or Belt Link. Don't know if they make roller chain now. I used to get to get the left over pieces when the shop replaced roller chain in the mill. They would always take a foot or so more than needed. I would get it and put the pieces back together. I like your way of getting cheap chain Don On 9/3/2012 at 8:58 AM, meadowfield said: Ian, c'mon with this update.... I know the answer... just waiting for the pics and video !!!!! Yes... Someone let the cat out the bag the other night Sorry guy's your going to have to wait a little while longer for the video's.. Yep, I did say "Video's".. Just like waiting for a bus, none turn up in hours, then 3 turn up at once. If all goes to plan I should get them uploading to MooTube overnight, so just a little longer to go... To tide you over until then, have a few photo's which might help explain how the test drive's went It might not look it due to all the grass, but it's quite a steep 2-ish foot climb... Not a problem Slightly blurred, but I like it. Share this post Link to post Share on other sites
bowtiebutler956 650 #748 Posted September 3, 2012 I can't wait for the video Ian! Thats awesome that its working now. I bet you have a smile thats perminately glued to your face! Matt :flags-texas: Share this post Link to post Share on other sites
Stigian 1,234 #749 Posted September 4, 2012 On 9/3/2012 at 10:23 PM, bowtiebutler956 said: I can't wait for the video Ian! Thats awesome that its working now. I bet you have a smile thats perminately glued to your face! Matt Thanks Matt, you need wait no longer for the vid's Part 37. Part 38.. Test driving. Share this post Link to post Share on other sites
Stigian 1,234 #750 Posted September 4, 2012 Err.. Having problems getting the 3rd vid linked.. Something about "Posting too much media"?? Share this post Link to post Share on other sites
