Pullstart 63,529 #2 Posted May 26, 2023 You sure find some interesting stuff Chuck! 1 1 Share this post Link to post Share on other sites
cafoose 3,360 #3 Posted May 26, 2023 12 minutes ago, Pullstart said: You sure find some interesting stuff Chuck! Sometimes I do. I was scrolling Facebook and that came up as a suggested post so I had to share 1 1 2 Share this post Link to post Share on other sites
8ntruck 7,256 #4 Posted May 26, 2023 Who is it on the forum who is working on a front mounted brush cutter for their Horse? Similar principle only using a Ford deck as a starting point. 2 Share this post Link to post Share on other sites
Ed Kennell 39,735 #5 Posted May 26, 2023 Which leg does he need Chuck. I have a left That I don't use and will trade for the brush cutter. 2 6 Share this post Link to post Share on other sites
SylvanLakeWH 26,591 #6 Posted May 26, 2023 3 hours ago, Ed Kennell said: Which leg does he need Chuck. I have a left That I don't use and will trade for the brush cutter. That's mighty generous... Might say you got a leg up on the other bidders... 4 3 Share this post Link to post Share on other sites
cafoose 3,360 #7 Posted May 26, 2023 3 hours ago, Ed Kennell said: Which leg does he need Chuck. I have a left That I don't use and will trade for the brush cutter. He doesn't specify. Either should work but the feet may be different 1 2 Share this post Link to post Share on other sites
cafoose 3,360 #8 Posted May 26, 2023 4 hours ago, 8ntruck said: Who is it on the forum who is working on a front mounted brush cutter for their Horse? Similar principle only using a Ford deck as a starting point. Since I moved to Tennessee I sure could use a front mounted brush cutter. Not working on one at the moment but it is a good idea. Using that one with a horse between you and the cutter it may work. Most body parts would be out of harm's way It could also double as a rodent eliminator. Maybe @Pullstart Kevin can get to work on it Definitely would need a seat switch 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 26,591 #9 Posted May 26, 2023 Just make sure you wear @Pullstart's patented safety sandals... be safe! 1 1 3 Share this post Link to post Share on other sites
ri702bill 8,737 #10 Posted May 26, 2023 2 hours ago, cafoose said: Since I moved to Tennessee I sure could use a front mounted brush cutter. Not working on one at the moment but it is a good idea. Using that one with a horse between you and the cutter it may work. Most body parts would be out of harm's way It could also double as a rodent eliminator. Maybe @Pullstart Kevin can get to work on it Definitely would need a seat switch Gopher Patrol....... 1 Share this post Link to post Share on other sites
cafoose 3,360 #11 Posted May 26, 2023 (edited) 7 minutes ago, ri702bill said: Gopher Patrol....... Edited May 26, 2023 by cafoose 1 Share this post Link to post Share on other sites
Wheel-N-It 2,969 #12 Posted May 27, 2023 What in the North Carolina Hillbilly Hades is that thing???? Oh yeah, I remember seeing one of those in a John Deere parts and accessories catalog. LOL 1 Share this post Link to post Share on other sites
Horse Newbie 7,168 #13 Posted May 27, 2023 (edited) 14 hours ago, 8ntruck said: Who is it on the forum who is working on a front mounted brush cutter for their Horse? Similar principle only using a Ford deck as a starting point. Not sure but I think you may be referring to @kpinnc… I just know that he said something like what he is building will only be used where no living animal, two or four legged, is around… Edited May 27, 2023 by Horse Newbie 2 Share this post Link to post Share on other sites
Mickwhitt 4,881 #14 Posted May 27, 2023 This is quite a beast of a brush cutter. 5mm Square nylon trimming line on a 4.5 hp Honda engine. It makes light work of heavy grass and brambles. I was thinking of mounting a Stihl brush saw blade on her to really clear some stubborn brush. 1 Share this post Link to post Share on other sites
cafoose 3,360 #15 Posted May 27, 2023 4 hours ago, Mickwhitt said: This is quite a beast of a brush cutter. I got one of these and it kicks butt A little difficult on the hills because it's not self propelled Share this post Link to post Share on other sites
Lee1977 6,917 #16 Posted May 29, 2023 I see the problem with that brush cutter. You have to be in front of it to start it. He's luck to have only lost one leg. 1 Share this post Link to post Share on other sites
cafoose 3,360 #17 Posted May 29, 2023 6 hours ago, Lee1977 said: I see the problem with that brush cutter. You have to be in front of it to start it. He's luck to have only lost one leg. Very observant I never even thought about that In that case, if I was to use that on the front of a horse I would have electric start on it Share this post Link to post Share on other sites
Tractorhead 9,065 #18 Posted May 29, 2023 On 5/26/2023 at 5:03 PM, 8ntruck said: Who is it on the forum who is working on a front mounted brush cutter for their Horse? Similar principle only using a Ford deck as a starting point. I did.... I think i. Bushes 2-3 cm thick should go with it But not a Ford Deck, i used a relatively cheap 2 Wheeler Attachement and reworked it for my Horse.. 4 Blades each disc with calculated 4200 rpm should be doing the Trick. And. Yes, it is not centered, because the Cutting zone is just 80cm and my 656 have 87cm width. so if i centered it, i would drive over the Cut what is a bad idea. 1 Share this post Link to post Share on other sites
