dgjks6 6 #1 Posted August 5, 2009 Well - my wife said I have to get rid of it, but after much soul searching I decided to stand up to her and tell her "No" - I am going to keep the c-85 and put in a new motor - if she will let me. But my question is this. My goal is to use my 312 for a snow blower or plow and the other (re-powered c-85) to run the one the 312 is not. Is an 8 horsepower motor enough to run a plow or a blower, or should I get a bigger motor? I see a ton of K-181's on ebay for cheap. Share this post Link to post Share on other sites
Kelly 1,030 #2 Posted August 5, 2009 An 8hp will plow, but not so good for a blower, if your going to buy a engine go bigger, they will bolt right in, we just repowered a C-85 with a 14hp, had to make some wires longer, and change the choke and throttle cables, everything else bolted right up. Share this post Link to post Share on other sites
pfrederi 18,181 #3 Posted August 5, 2009 For one winter I used a C-81 with a blower. It worked...but the motor was definitely struggling and I was in Low range 2-3 most all the time. I have also tried a C175 on the blower (she is a beast High range all the time) and last year used a Charger 12 Auto. Went a bit slower but she handled it well enough. Share this post Link to post Share on other sites
TT-(Moderator) 1,145 #4 Posted August 5, 2009 I just bolted an 18hp B&S Vanguard V-twin on a C-85 using all WH parts. I did it mainly to check the condition of the engine (sort of a test stand), but once I got it running, I hooked up the PTO clutch, etc. enough to try it on a 48" mower deck. I mowed a full swath of weeds/grass taller than the hood and it barely bumped the governor. Kinda looks like it belongs there, huh? I won't tell you that the Vanguard twins are the best engines out there, but we do have a few in service where I work. One has just over 2800 hours on it and has never had anything done to it except 100 hour oil & filter changes. Share this post Link to post Share on other sites
bo dawg 516 #5 Posted August 5, 2009 That's cool You ought to keep it like that TT. Share this post Link to post Share on other sites
can whlvr 993 #6 Posted August 6, 2009 I must agree to go bigger,i had a 308-8,now repowered with a honda 13 and there is no comparison,this machine is much stronger now and i could let the grass go a little longer before i had to cut it.I couldnt afford a big kohler at the time,so a brand new pull start is what she got.I am on my second honda now (loose air cleaner) ,the thing i like about it is no batterys,starters wiring problems,safty switches,ignitions etc,and it allways starts first pull,one draw back,no lights. Share this post Link to post Share on other sites
dgjks6 6 #7 Posted August 6, 2009 I kinda like the honda repower. There are some cheap motors just like that on ebay now. And I will not have to buy a new battery or worry about the electronics. Can I get some moe pictures? Like how the PTO hooks up and drive belts hooks up. Do they come with the same size drive shaft? Share this post Link to post Share on other sites
can whlvr 993 #8 Posted August 7, 2009 The honda was almost a direct bolt in other than the fact that the crankshaft on the honda is flared right beside the bearing where the shaft comes out,so i dremeled the pulley,plate hole to fit the flare on the crank,and i had to remove the head lights because the exhaust blows out the front,no big deal because the pull start doesnt run lights anyway ,this motor is a torque monster and i dont like to admit it but is even stronger than my 14 kohker,they just dont last as long,but if you take care of it i had one go 10 years of extreme use untill i didnt tighten the air cleaner and that was the begiining of the end for thet motor.Here is a few more pics. Share this post Link to post Share on other sites
