jdog_kustoms 82 #1 Posted August 2, 2009 what trans is in a 416-8 tractor im lookin at it but it doesnt feel like it goes in any gear when you move the shifter just curous what other trans would work Share this post Link to post Share on other sites
Duff 206 #2 Posted August 2, 2009 Jdog, as far as I know any 8-speed with 1-1/8" axles should fit the 416-8. Before you junk the tranny you have, though, you might want to either take the shifter out and be sure the end didn't snap off, or open the tranny up to see if a shifter fork went south. Since you'll have to take the tranny off anyway, this might save you some money. Duff :thumbs2: Share this post Link to post Share on other sites
can whlvr 994 #3 Posted August 3, 2009 It is possible that your shifter set screw has backed off and the shifter has moved out of the forks,if your lucky you just realign the shifter in the forks and tighten the set screw,good luck. Share this post Link to post Share on other sites
can whlvr 994 #4 Posted August 3, 2009 here is a pic of the bolt i am talking about Share this post Link to post Share on other sites
jdog_kustoms 82 #5 Posted August 3, 2009 can whlvr can you pull your shifter out and take a pic i can only get it in 2nd or 3rd gear but the shifter comes up in the reverse and 1 spot and it is just a straight rod is there suposed to have a ball on it and what does the set screw look like mine has about a 3/16 to 1/4 haft on the end and the rest is threaded but luckally this and a loose hub is all thats wrong with it pics on the way thanks for everyones help Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #6 Posted August 3, 2009 If you look at the picture above you can actually see the ball. It's machined on the end of the shifter just below a turned down section and you'd be able to tell by looking at the end of your shifter if it was broke off. The set screw actually looks like this: It should only have one Share this post Link to post Share on other sites
jdog_kustoms 82 #7 Posted August 4, 2009 my set screw looks just like that and here is pics of my shifter rod and the shifter on the hole with set screw tight Share this post Link to post Share on other sites
jdog_kustoms 82 #8 Posted August 4, 2009 the last picture is the shifter forks on either side its just a big open hole Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #9 Posted August 4, 2009 There's supposed to be a larger pivot ball fastened to the shifter by a roll pin through the hole the set screw is currently in. (the setscrew goes into the hole in the pivot ball) There's a good possibility it's inside the tranz and it really should be removed. I don't have a picture of a shifter but can get one if no one else has one. Share this post Link to post Share on other sites
jdog_kustoms 82 #10 Posted August 4, 2009 how hard is it to split the case i need a new gasket also or do gears go every were Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #11 Posted August 4, 2009 If you can get the right wheel hub and input pulley off easily, then it's a "piece of cake". You will definitely need a new gasket for the case halves and you might even want to think about new axle/brake shaft/input shaft seals while you're that far. If you separate the case halves slowly and carefully you shouldn't have any pieces flying across the room. (The Uni-Drive manual is available for download at Toro.com) Share this post Link to post Share on other sites
oldandred 16 #12 Posted August 4, 2009 heres a picture of what it looks like Share this post Link to post Share on other sites
