Electro12WH 50 #1 Posted August 2, 2009 I have a '74 C 160. What pinion count does this have? Is it limited slip? Is this the strongest trans WH made? Share this post Link to post Share on other sites
nylyon-(Admin) 7,345 #2 Posted August 2, 2009 You should have the 8 pinion trans, which is the strongest. It is not limited slip. Share this post Link to post Share on other sites
Raider12 13 #3 Posted August 2, 2009 I have a '74 C 160. What pinion count does this have? Is it limited slip? Is this the strongest trans WH made? From what I have read, there is very few models that have limited slip diff. The Raiders from 1970 to 1974 I believe are it. Someone chime in and correct me if this isn't correct. Share this post Link to post Share on other sites
oldandred 15 #4 Posted August 2, 2009 the transmission numbers were 5073 these are 8 speed and 10 pinion used in the 1970 raider 10,12, in numbers 1-6051 1-6251 1-6253 and 1971 raider 10,12 1-0300 1-0310 1972 raider 10,14 1-0311 1-0320 1973 12hp no name tractor 14 " " " " 1-0350 1-0340 thats were they are used Share this post Link to post Share on other sites
