Electro12WH
Trans Size
Electro12WH
I have a '74 C 160. What pinion count does this have? Is it limited slip? Is this the strongest trans WH made?
nylyon
You should have the 8 pinion trans, which is the strongest. It is not limited slip.
Raider12
From what I have read, there is very few models that have limited slip diff. The Raiders from 1970 to 1974 I believe are it. Someone chime in and correct me if this isn't correct.
oldandred
the transmission numbers were 5073 these are 8 speed and 10 pinion
used in the 1970 raider 10,12, in numbers 1-6051
1-6251
1-6253
and 1971 raider 10,12
1-0300
1-0310
1972 raider 10,14
1-0311
1-0320
1973 12hp no name tractor
14 " " " "
1-0350
1-0340
thats were they are used
