mort 24 #51 Posted June 10, 2023 6 minutes ago, pfrederi said: Thank you! I haven't had a chance to test out the coil or look at the points yet. Mort Share this post Link to post Share on other sites
pfrederi 18,331 #52 Posted June 10, 2023 1 hour ago, mort said: Thank you! I haven't had a chance to test out the coil or look at the points yet. Mort There are no points on a magnum Share this post Link to post Share on other sites
mort 24 #53 Posted June 10, 2023 Thank you! I don't know if you looked at the thread but I got it working and then it stopped. I thought it was running hot and it smoked some near the muffler area after it stopped. I am not getting any spark anymore. Since it doesn't have points does that point to the coil or is there a ignition module like the Onan has? Thanks, Mort Share this post Link to post Share on other sites
pfrederi 18,331 #54 Posted June 10, 2023 25 minutes ago, mort said: Thank you! I don't know if you looked at the thread but I got it working and then it stopped. I thought it was running hot and it smoked some near the muffler area after it stopped. I am not getting any spark anymore. Since it doesn't have points does that point to the coil or is there a ignition module like the Onan has? Thanks, Mort There is a module 52 584 02 and a specified air Gap for it. Share this post Link to post Share on other sites
mort 24 #55 Posted June 10, 2023 Thank you! I did clean out that area (mouse bedding) and removed the coil and bolted it back in place. I didn't check the gap (didn't know better) and because there wasn't a lot of movement available. I spaced that "slight" gap evenly maybe the same as a business card. Would it start if the gap was incorrect? I doubt that the space changed but it could have. I noticed on the Magnum manual that you sent down that the spark plug they listed was a RV17YC (.035 gap) my Wheel Horse 418A manual says RV15YC (.035 gap) Would that RV15YC make the engine run hotter than normal and could that have blown the coil? Thanks, Mort Share this post Link to post Share on other sites
mort 24 #56 Posted June 16, 2023 On 6/10/2023 at 11:06 AM, pfrederi said: There is a module 52 584 02 and a specified air Gap for it. On 6/10/2023 at 11:06 AM, pfrederi said: There is a module 52 584 02 and a specified air Gap for it. Question for you.......... The Kohler manual shows the ignition module to magnet air gap is .008/.012 Why the two numbers? My feeler gauge shows either.008/0.20mm or .012/0.30mm Which one is correct? Thanks, Mort Share this post Link to post Share on other sites
Handy Don 13,340 #57 Posted June 16, 2023 3 hours ago, mort said: The Kohler manual shows the ignition module to magnet air gap is .008/.012 Why the two numbers? My feeler gauge shows either.008/0.20mm or .012/0.30mm Which one is correct? Both are in inches and together they define the acceptable range for the gap which is OK anywhere between For example, if you measure and come up with .010, you need not futz with trying to get it any closer! Share this post Link to post Share on other sites
mort 24 #58 Posted June 17, 2023 2 hours ago, Handy Don said: Both are in inches and together they define the acceptable range for the gap which is OK anywhere between For example, if you measure and come up with .010, you need not futz with trying to get it any closer! Thank you! Mort 1 Share this post Link to post Share on other sites
mort 24 #59 Posted June 17, 2023 Quick update....replaced the coil and it immediately started.I could start it with just a turn of the key. Still think it might be running hot only because the cooling fins/cylinder head area is smoking a little plus i need to keep the choke out or it will stall. I maybe ran it for 5 or so minutes but really didn't look at my watch. I didn't want to burn up another coil. What would be reasons why I need to keep the choke open? Still would like to get an answer on this question.....I noticed in the Kohler Magnum manual that the spark plug they listed was a Champion RV17YC (.035 gap) my Wheel Horse 418A operator's manual says Champion RV15YC (.035 gap) Would that RV15YC make the engine run hotter than normal and could that have blown the coil? I also noticed that the Champion RV17YC is suppose to run hotter. Is that a good thing or a bad thing? Why? I never saw to manuals that showed two different spark plug under specifications. The Wheel Horse 418A parts and service manual (810 480R1) even shows a different Champion spark plug all together. Lots of confusion here! Anybody have better pictures of how to adjust a 418A neutral linkage adjustment as the tractor creeps after the brake pedal is depressed? Automatic Transmission Neutral Adjustment on page 79/80 in the parts and service manual is not too good at all! Thanks, Mort Share this post Link to post Share on other sites
pfrederi 18,331 #60 Posted June 17, 2023 Too lean a fuel mixture will make an engine run hot and make it prone to stall under load. Choking richens it. I have run the RV17 for as long as I have had-it (several years). I think they came with Walbro fixed main jet carbs. If that is the case your lean condition is probably due a to partly blocked jet. More car cleaning is in order.... Share this post Link to post Share on other sites
mort 24 #61 Posted June 18, 2023 9 hours ago, pfrederi said: Too lean a fuel mixture will make an engine run hot and make it prone to stall under load. Choking richens it. I have run the RV17 for as long as I have had-it (several years). I think they came with Walbro fixed main jet carbs. If that is the case your lean condition is probably due a to partly blocked jet. More car cleaning is in order.... Thank you! Mort Share this post Link to post Share on other sites
mort 24 #62 Posted June 19, 2023 On 6/17/2023 at 9:52 PM, mort said: Thank you! Mort I used some Seafoam down the throat and let it sit over night. Then I turned the engine and let it sit for a while. Started right up. Running better and then I noticed the throttle wasn't doing anything as the linkage was stuck. Still not 100% but better Thanks, Mort Share this post Link to post Share on other sites
