Joenieu 0 #1 Posted May 22, 2023 Can anybody help to diagnose the problem? Share this post Link to post Share on other sites
oliver2-44 10,351 #2 Posted May 22, 2023 Is the drive belt moving, but the tractor not moving? Check if the transmission drive pulley is loose on the shaft Also check if one of the axles is spinning in a loose hub. Is the belt idler pulley putting enough tension on the belt or is the spring to weak? Work your way through the drive system and tell us what’s moving and what’s not moving. 1 Share this post Link to post Share on other sites
Terry M-(Moderator) 2,203 #3 Posted May 22, 2023 You say “ unable to climb hill”. Maybe you can provide a little more information…. Are you talking about an engine power issue, or a traction issue? 1 Share this post Link to post Share on other sites
Pullstart 64,468 #4 Posted May 22, 2023 The input pulley has a set screw and should have a keyway, like the engine pulley. If either are compromised, the pulley may be turning on the shaft but since low range is more reduction, the set screw may be holding. All of this is speculation without more help from your observations… Share this post Link to post Share on other sites
ranger 1,774 #5 Posted May 22, 2023 (edited) The C161 I have just bought had a similar problem. Won’t move in 3high, on gradients, fine in other gears. Reason, wrong type of drive belt. It did not have the Kevlar? Reinforcement and had stretched in one section, and thinned, ( like a stick of liquorice when pulled). Fitting correct belt completely cured the problem, much quieter too. Edited May 22, 2023 by ranger 2 1 Share this post Link to post Share on other sites
953 nut 57,839 #6 Posted May 22, 2023 Your belt is probably shiney and worn-out. Go to Tractor Supply and buy a Kevlar 5/8 X 83 belt and away you go. 3 Share this post Link to post Share on other sites
squonk 42,505 #7 Posted May 22, 2023 (edited) Yup. First thing to check is the belt. And don't let anybody tell you that you have to use a WH belt either. TSC or Napa is fine Edited May 22, 2023 by squonk 1 Share this post Link to post Share on other sites
