Tim.0
314-h transmission engage lever
Tim.0
HI, Been long time since posted here. Hope all is well with everyone.
Looking for a picture or explanation of the springs which go to the lever to engage the transmission. Last year springs broke. I went to hardware store and bought a spring to fix. Works but not exactly the way it should. Anyhow I have 2 springs coming, but not sure how to put them on so the lever works properly. I can not find a picture in manual as to how they are installed properly.
Any help would be appreciated. Thank You very much.
Tim O
Ed Kennell
Edited by Ed Kennell
Tim.0
Thank You so much. Something to go off of.
Handy Don
For me, it is much easier to put the belt on and then attach the spring than the other way.
I loop a piece of wire through the end of the spring and grip that loop with vice grips below the frame to give me a good hold of the spring. Once it’s on the screw, then I add the nut.
Eye protection when working with springs, of course.
