D_Mac
310-8 With a nice story.
Sparky
Awesome story…a tractor with some history!
  Does look to be in great shape
kpinnc
16 minutes ago, D_Mac said:
Wondering what kind of damage that tiny brass screw can cause if it got sucked into the engine.
You'll know if it happens. My 310-8 sucked in a brass crew from a carb rebuild that the dingbat owner (me) didn't swedge them because he ASSUMEd Loctite would suffice. :rolleyes:
Anyway- it didn't crack the head, but it sounded like two hammers in a clothes dryer. When I removed the head, the brass screw was flat as a pancake. Luckily nothing was broken, and the Magnum 10 ran fine for another 15 years.
So- remove the head. If the screw isn't there, check closely in the intake. Maybe you got lucky and it's in the muffler.
  • Like 4
ineedanother
Great story and a decent price too :lol: I've never seen a throttle plate fall off and finding it would be a priority. If it was in fact the throttle plate, it wouldn't have run for long which is a good thing. If it was the choke plate, well it might have run a bit and my hope would be that it never made it past the intake valve. Definitely pull the carb first, then the head to see if it's still there and what potential damage there might have been if it made it's way into the cylinder. Those screws are soft and if it made it that far I suspect it got spit out the muffler pretty quickly.
D_Mac
All we saw so far was just the throttle plate laying unattached in the carb. One of the 2 screws missing that hold the plate. My buddy said same thing. Hopefully it's in the muffler and not the engine but no way of really saying without pulling the head.
mrc
you should change your name from D Mac to   'LUCKY'
 great score!
gwest_ca
If the serial number is 21377 it is likely a 1987 model 21-10K804
WHGuy413
I love a good horse story. Glad you were able to save it and in such great shape too.
oliver2-44
I have a kohler 14hp off a JD that I picked up as a complete/parts engine with a new Chinese carb on it.
Opened it up and the top of the piston had a lot of little dents.
I'm guessing the original carb lost some screws and it made noise so they scrapped it. No sign of the screw.
It would probable run like it is, but I'll at least replace the piston if I were to put it in a worker tractor.
As others said, I would pull the head for and inspection.  Get some new screws for the carb and repair it.
A 48" deck seems large for a 10hp!  PO must have really kept his grass mowed!
Edited by oliver2-44
Wheel-N-It
Thats the nicest free Wheel horse I've ever seen !!!  Congratulations, you must be living right :)
And a 48" SD deck to boot !  Good score
D_Mac
Update on the free 310-8. I called the previous owner last night to thank him again for giving it to me. We talked about why he brought it into the shop. He told me that it was able to run in its condition but the engine raced with the throttle being wide open. He said it didn't make any funny noise only that it was running full throttle. Like I said I have not even tried to start it yet. Going to remove the head and check for damage first. He also said he installed that push button on the dash to start it because sometimes the key switch didn't work. We Will look into that as well. More to come.
Edited by D_Mac
Skwerl58
Great story! I had a 1971 Sears Custom 10 with a 10 hp Techumseh that the plate screw came off of and bent a valve. The valve was stainless and and cost $30+ probably 35 years ago. I installed the new valve, replaced the screw and it ran well until parked by my son about 8 years ago. My grandson wants to get it going so it is on my summer list of things to get done!
  • Heart 1
D_Mac
So we removed the head today. All looks well inside. The screw must have passed out the exhaust. The bad news is there is no saving the carb. The hole where the throttle shaft passes through is all whollowed out at the top. Same with the plate holes. Relief to know there was no damage to the inside of the engine. Will look for a carb and do some other maintenance in the mean time.
D_Mac
So head gasket ordered, looking for a carb. If everything goes right I might consider trading this 48inch deck for a 42. Thoughts on running a 48 on a 10hp ? I know the PO did fir many years with no issue. I would swap mainly for storage reasons. I have little space.
squonk
Go to Ace Hardware. Pick up 2  7/16" x 1/4" x 1/16" bushing/washer  from their pull out drawers. Stack them on top of each other in the counter bore. Then you will need 2 3-48 screws if you have a Carter carb or 2 4-40 screws if it's a Walbro. Some loctite thread locker and peen the threaded ends after installing the plate. IMG_20180216_180707968-min.jpg.97fc5cc6d78a8ca3c1009a27fad1a087.jpg
  • Thanks 2
Wheel-N-It
You can try running the 48, but the blades will have to be sharp, and the grass not too tall. I have mowed with a 48 inch deck on a 12hp hydro Wheel Horse, and thats pushing the limits. Yours is a gear drive, so you don't have to use any of that power/torque to spin a hydro pump. Also set the rpms on that Kohler with a tachometer. You want to have all the rpm's that Kohler is designed to run at.
D_Mac
Lol Mike you know that's beyond my "skill" level.
squonk
It's not any harder than that head gasket. You can play "China Roulette " with a new carb or bring the carb to me and I'll fix it.
D_Mac
Well you know that's not my garage it is in. My friend dosnt do stuff like that. He is set on finding new carb. Lol... even though the tractor is mine I have no say when it comes to the repairing.
elcamino/wheelhorse
@D_Mac try I save tractors , had good luck with their carbs,
D_Mac
I have a carb I got for my 1075 while back. We are going to try that one.
  • Similar Content
    • D_Mac
      By D_Mac
      Made the trip out to Tractor Supply Store today to pick up some paint. Walked around the store and found they had these seats on " clearance" .... $30.00... So I grabbed one. Can not pass up a new seat for that price. Think I will put it on the Lambert. just thought I would pass it on. Not sure if all stores are getting rid of them or not.
    • ebinmaine
      By ebinmaine
      Just wanted to share this with the crowd here. I know there's a lot of you out there that prefer these for removing light rust and paint from metal or even other surfaces.
      This is a 5 pack and they work out to $6 each. Free freight.
      Lots of reviews online say they are the cat's meow of these strip discs.
      I'll share my findings with you.
    • GlenPettit
      By GlenPettit
      Lawn Mower Storage Mistakes Exposed! View this email in your browser Lawn Mower Storage Mistakes Exposed!
      Do you want your mower to start back up after several months in hibernation? Then properly preparing it for winter storage is crucial.
      Mistake #1: Not Draining Old Fuel
      Get that gas out! Drain the tank & fuel bowl, so the gas won't deteriorate, gum-up, and damage the fuel system & carburetor.
      See more Storage Mistakes to Avoid »   Fuel Stabilizers Oil Oil/Fuel Extractor Storage Covers   Share Tweet Forward   Shop for Parts | Shop for Equipment | DIY | Ordering Information | Check Order Status | Find Us | DisclaimerCopyright © 2016 Jacks Small Engines, 1745 Jarrettsville Road, Jarrettsville, MD 21084, All rights reserved.
      You are receiving this email because you opted in at our website For order related questions please contact our customer support team at orders@jackssmallengines.com. Please do not reply to this e-mail.Thank You!
      unsubscribe from this list    update preferences  F.Y.I.
      This is a free monthly newsletter, with very timely suggestions  (just click: 'Storage Mistakes to Avoid >>'  to open the entire newsletter), it is full of informative and interesting articles each month, almost like a magazine.  If you have ordered from Jacks in the past, you may already be getting it, otherwise, just eMail and ask to be put on their mailing, you will only get this newsletter, no other junk mailings.  Their forum responses are also very interesting, I'm always getting lots of new ideas from this.
      Glen
      This is a really great newsletter, for all brands, great timely tips & suggestions, plus viewers comments –– not a heavy 'buy our products' thing; you may already get it if you have ordered from them, or just contact and ask to be added.  Their site is packed with ideas & info.
    • WHX??
      By WHX??
      Well went to see Dennys502 in MN while on vacation last week and picked up this 400 he was giving away. Story has it this came from VA after the owner was injured on a WH (not this one)  and he told Toro he didn't want it. Toro legal possibly had it shipped back to MN where Denny worked for Toro and legal asked him if he wanted it. He planned to do somewthing with it but since he is now retired and too busy...lol... He wanted another member to maybe have a crack at it so here we are. Still awfully nice for him to give it away and i promised that if I can't do anything with it I would pass it along to someone else here. We believe it to be an early 60's hence the Clinton motor and seat with out holes. More pictures of it and a different thread once I get going on it.
