formariz 11,987 #1 Posted May 8, 2023 Already owning and using constantly several of these vintage drills I was happy yesterday when I came across this NOS beauty for a whopping $5.00. Even with hard use I am sure it will be around long after anything made today. 6 6 3 Share this post Link to post Share on other sites
Handy Don 12,237 #2 Posted May 8, 2023 Enjoy it! I could no longer work comfortably with a cord (including extension cords) and without a keyless chuck, reverse, and variable speed. But that’s me. 2 Share this post Link to post Share on other sites
squonk 41,156 #4 Posted May 8, 2023 24 minutes ago, formariz said: Already owning and using constantly several of these vintage drills I was happy yesterday when I came across this NOS beauty for a whopping $5.00. Even with hard use I am sure it will be around long after anything made today. My Grandfather had one of those. I can still see it hanging by a nail by his work bench! 1 Share this post Link to post Share on other sites
ri702bill 8,345 #5 Posted May 8, 2023 Is that a "keyless" chuck?? 2 prong, probably non-polarized cord, metal housing-- there's a reason they don't make them that way... The 1/4" chuck is way old school - I buy all 1/2" cordless ones now.. My Dad had one similar mounted in a small drill press stand. I remember the distinctive gear whine it made, along with the sparking brushes!! Share this post Link to post Share on other sites
formariz 11,987 #6 Posted May 8, 2023 12 minutes ago, Handy Don said: Enjoy it! I could no longer work comfortably with a cord (including extension cords) and without a keyless chuck, reverse, and variable speed. But that’s me. I keep several each with a commonly uses bit such as with one with a countersink. No reverse needed on those. Drilling speed is ideal on these old drills. This chuck does use a key. It’s an hex-key chuck. 1 2 Share this post Link to post Share on other sites
formariz 11,987 #7 Posted May 8, 2023 (edited) 4 minutes ago, ri702bill said: Is that a "keyless" chuck?? Edited May 8, 2023 by formariz 2 2 Share this post Link to post Share on other sites
formariz 11,987 #8 Posted May 8, 2023 (edited) 7 minutes ago, ri702bill said: 2 prong, probably non-polarized cord, metal housing-- there's a reason they don't make them that way... Over 40 years of using them. Nothing to fear but fear itself Edited May 8, 2023 by formariz 1 2 1 Share this post Link to post Share on other sites
formariz 11,987 #9 Posted May 8, 2023 24 minutes ago, squonk said: My Grandfather had one of those. I can still see it hanging by a nail by his work bench! Share this post Link to post Share on other sites
formariz 11,987 #10 Posted May 8, 2023 32 minutes ago, ri702bill said: My Dad had one similar mounted in a small drill press stand Share this post Link to post Share on other sites
formariz 11,987 #11 Posted May 8, 2023 Real interesting stuff. I never had the instructions for one before. Here is what instructions say in reference to grounding. None of mine however have that wire depicted in instructions. 2 Share this post Link to post Share on other sites
formariz 11,987 #12 Posted May 8, 2023 I stand corrected. Upon closer inspection of plug what looked life a pulling aid is actually where ground wire is. Looks like it was cut off. Will then install the proper plug . 1 Share this post Link to post Share on other sites
rmaynard 15,514 #13 Posted May 8, 2023 My dad had one exactly like this in the 1950's. He got tired of trying to find somewhere to ground the green wire, so he too cut it off. He was never electrocuted, nor did he ever admit to getting a shock or even a buzz from the drill. Share this post Link to post Share on other sites
ri702bill 8,345 #14 Posted May 8, 2023 (edited) 6 hours ago, formariz said: Over 40 years of using them. Nothing to fear but fear itself Shorts to the shorts!!!!! NOT a good day!!! Edited May 8, 2023 by ri702bill Share this post Link to post Share on other sites
cafoose 3,355 #15 Posted May 8, 2023 5 hours ago, formariz said: Looks like it was cut off. Will then install the proper plug If it was mine I would put a three prong grounding plug on it and attach the grounding wire from the cord to the drill frame. Then you could plug it into a three prong outlet and it would be properly grounded. 2 Share this post Link to post Share on other sites
EB-80/8inPA 1,655 #16 Posted May 8, 2023 Love that Flash Gordon design for the space age. 1 Share this post Link to post Share on other sites
formariz 11,987 #17 Posted May 8, 2023 9 minutes ago, cafoose said: If it was mine I would put a three prong grounding plug on it and attach the grounding wire from the cord to the drill frame. Then you could plug it into a three prong outlet and it would be properly grounded. Already done. All the others were done also long ago. The old cords turn to mush after so many years also. 4 Share this post Link to post Share on other sites
formariz 11,987 #18 Posted May 8, 2023 20 minutes ago, ri702bill said: Shorts to the shorts!!!!! NOT a good day!!! I never wear shorts while working. 2 Share this post Link to post Share on other sites
mrc 812 #20 Posted May 9, 2023 i get the whole electrical grounding thing but, .stuff made years ago just looks tuff! everything today is plastic crap. 1 Share this post Link to post Share on other sites
8ntruck 7,018 #21 Posted May 9, 2023 That is the kind of drill I learned on. Seeing the picture brought back the ozone & oil smell it always had and the 'gear music' it made when running. 2 3 Share this post Link to post Share on other sites
formariz 11,987 #22 Posted May 9, 2023 11 hours ago, 8ntruck said: That is the kind of drill I learned on. Seeing the picture brought back the ozone & oil smell it always had and the 'gear music' it made when running. At least for me a big part of the attraction to everything old is exactly what you mention such as also the smell of an old tool chest when opened or the smell in a vintage car to name a couple. There is always a nostalgia associated with them . When people walk into the shop that is usually the first comment referring to a certain smell that reminds them of something in their past. I am so used to them that many times I no longer notice them. Share this post Link to post Share on other sites
Lee1977 6,670 #23 Posted August 21, 2023 (edited) Here is my 1/4" drill it's a Sears Craftsman I bought new back in 1955. Still runs as good as it ever did. Also have a 1/2" Sears Craftsman bought sometime in the 60's the only 1/2" hand drill I have had Not new but the still get the job done. Took me 70 years before I could buy something with out thinking do I really need to spend money on this. I have a Black & Decker 3/8" professional that I use the most. Edited August 21, 2023 by Lee1977 Share this post Link to post Share on other sites
