chev0545 234 #1 Posted May 8, 2023 does a 88 518 need the snow plow extension Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,919 #2 Posted May 8, 2023 Not according to the attachment chart 2 Share this post Link to post Share on other sites
kpinnc 11,498 #3 Posted May 8, 2023 The domestic 518-H used the Eaton 700 transmission. The European 518-H used the Eaton 1100. So if your tractor doesn't have hydraulic lift, it's a domestic model. Per the manual, they shouldn't use any ground engaging attachments. That 700 series pump won't tolerate the loading that the 1100 will. It produces about 1/3 of the torque. Depending on what you push with it, you can destroy the transmission. Share this post Link to post Share on other sites
lynnmor 7,245 #4 Posted May 8, 2023 15 hours ago, chev0545 said: does a 88 518 need the snow plow extension The extension is only needed for the tractors with the swept forward front axle that is found on most 520 tractors. Share this post Link to post Share on other sites
Handy Don 11,886 #5 Posted May 8, 2023 9 hours ago, kpinnc said: That 700 series pump won't tolerate the loading that the 1100 will. It produces about 1/3 of the torque. Depending on what you push with it, you can destroy the transmission. I can attest to this. 700’s are great for mowing the lawn or blowing snow. Pushing one at more than crawl speed will wreck it VERY quickly (you’ll see metal flecks in the oil reservoir). 1 Share this post Link to post Share on other sites
