Redav72 227 #1 Posted May 6, 2023 I'm planning to do an electrical overhaul of an 85 310-8 that I just purchased. What size wire should I get (10, 14AWG?) and where can I get a variety of colors to recreate the wiring harness. Share this post Link to post Share on other sites
953 nut 55,324 #2 Posted May 6, 2023 For general wiring such as Magneto to ignition switch, solenoid to ignition switch, lights, safety switches and hour meter I would use 16 AWG. The wire from the voltage regulator should be 12 or 14AWG and the wire from the battery to 30 amp fuse then on to your ignition switch should be 12AWG. The battery cables to ground, solenoid and to the starter should be 6 AWG. DelCity https://www.delcity.net/ is the best place to buy good quality terminal ends and the 6 AWG leads. The colored primary wires they sell are in 100 foot rolls for $ 12.30, the 30 foot roll you would get at the local auto parts store is about $ 12 with three colors available while DelCity has a good selection of colors and it is good quality copper wire. Do not use terminal ends from Harbor Freight. 1 Share this post Link to post Share on other sites
pacer 3,173 #3 Posted May 6, 2023 Another option I've used a couple times is getting a trailer tail light 'kit', it has about 20' of wire and has some ....8-10?wires of all different colors and is very reasonable (been too long since I bought one so cant even guess at cost!) I found that at TSC. TSC also has a pretty good selection of wire conx in small amounts - if you only need 2-3 instead of buying in bulk quanities. Share this post Link to post Share on other sites
953 nut 55,324 #4 Posted May 7, 2023 10 hours ago, pacer said: if you only need 2-3 instead of buying in bulk quanities. At DelCity the price for a 100 foot roll is about the same as a small amount at retail stores and shipping is free on orders of $ 50 or more. The left over wire could be traded with someone who needs it or sold. They also sell the Packard 56 wiring terminals which are far better than the ones you can find most places. The 7 wire trailer wiring harnesses are generally 12 AWG which is heavier than needed. 1 Share this post Link to post Share on other sites
Handy Don 12,237 #5 Posted May 8, 2023 On 5/6/2023 at 9:28 AM, pacer said: Another option I've used a couple times is getting a trailer tail light 'kit', it has about 20' of wire and has some ....8-10?wires of all different colors and is very reasonable (been too long since I bought one so cant even guess at cost!) I found that at TSC. This is a good option, but be sure to read the fine print. Many of these kits come with aluminum core wiring with a copper coating, not solid copper. Share this post Link to post Share on other sites
Lee1977 6,673 #6 Posted May 9, 2023 I used 14 gage copper bought six 50' rolls of ebay I think it around $20 the colors were red, black, white, blue, yellow, and green. Share this post Link to post Share on other sites
