1940willys
What Trans Lubrication
1940willys
Sorry but I'm not sure what to put in the Uni Drive 4 speed manual transmission.  B 80  Model 101409  Serial 59721 Thanx in advance
rjg854
85 weight gear lube
oliver2-44
80 or 90 wt gear lube.  Even some 80w140 would be fine.  I use store brand nothing exotic required.
1940willys
Ok thanx for the speedy replys. Next Question is where is the easiest place to add lube to the Trans? I can't seem to find a Fill Tube / Dip Stick on this model like the one on my C101?
rmaynard
I remove the shifter and pour in there.
1940willys
Once again thanx for you speedy replies! Are all seals and bearings available for this Transmission. B 80  Model101409   Serial 59721 ?
rjg854
yes, check with our vendor Wheel Horse Parts and More
stevasaurus
I find it easier to remove the seat and fenders and use the 2 bolt holes on the top of the trans...one for a funnel, the 2nd for air release.  Fill until it starts to flow out of the fill plug on the left side...1 1/2 to 2 qts.  :occasion-xmas:
Edited by stevasaurus
1940willys
How do I know what Transmission this is? I know it's a  B 80 and a 4 speed it has 1" axles and the Serial 59721 and Model 101409. So if I want bearings and seals and go over to say Wheel Horse Parts and More I see Numbers. Where is a exploded diagram showing me my trans? Thanx.
rmaynard
Go to the manuals section and download the following:
