tallen4392 71 #1 Posted April 25, 2023 Does anyone know the size or part # for a 312-8 drive belt ?? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,845 #2 Posted April 25, 2023 Transmission drive belt 78-7100 replaced by 7473 - HB x 81.9" or 5/8" x 81.9" 3 Share this post Link to post Share on other sites
ebinmaine 75,744 #3 Posted April 25, 2023 4 hours ago, tallen4392 said: Does anyone know the size or part # for a 312-8 drive belt ?? On a manual transmission tractor you'd be ahead of the game to order a real OEM belt. 1 Share this post Link to post Share on other sites
squonk 44,860 #4 Posted April 25, 2023 TSC 5L820 or Napa 5L820W are fine to use Share this post Link to post Share on other sites
tallen4392 71 #5 Posted April 25, 2023 can i use any 5/8 x 82 belt ?? Share this post Link to post Share on other sites
ebinmaine 75,744 #6 Posted April 25, 2023 3 minutes ago, tallen4392 said: can i use any 5/8 x 82 belt ?? It has to be a cloth sided belt. Share this post Link to post Share on other sites
peter lena 9,556 #7 Posted April 25, 2023 @tallen4392 also check out your related idler pulley on that , typically those tiny original bearings , get funky / rough noisy , tractor supply has a same size unit with bigger rubber side shields , insert a short bronze bushing to make it a size to size fit . personally would pop off the bearing shields , clean out and re grease with a hi temp grease. reinstall shields , also lubricate related chassis linkage / lever areas , grease / oil . make for quiet / smooth operation . guy I just sold a horse to , thought the clutch pedal was different , turned out he was used to stiff / rusty linkage , marveled at its smooth engagement . gave him a list to follow , probably never looked at again , pete Share this post Link to post Share on other sites
squonk 44,860 #8 Posted April 25, 2023 Do NOT use a Std. B Series (B79) belt 2 Share this post Link to post Share on other sites
clueless 3,331 #9 Posted April 25, 2023 Just buy the OEM 7473 belt, it's the correct belt and it fits properly, it cost more but it should last you another 30+ years . 2 Share this post Link to post Share on other sites
