Frank DeHaven 27 #1 Posted April 24, 2023 Okay so I have my engine running but it seems like I have to keep the key turn to the start position or the engine will shut off. I have a new coil, condenser, and points. Does anyone have any other suggestions? My tractor is a c120 automatic with a 12 horse power Kohler. Thanks in advance Share this post Link to post Share on other sites
squonk 41,940 #2 Posted April 24, 2023 Sounds like a bad key switch if the wiring hasn't been altered. 3 Share this post Link to post Share on other sites
pacer 3,174 #3 Posted April 24, 2023 Your battery wire and solenoid wire are 'together' for some reason - and, most probably the switch is bad ... but, if the wires have been 'messed' with the wiring could be crossed.... 2 Share this post Link to post Share on other sites
wallfish 17,193 #4 Posted April 24, 2023 (edited) It's not getting power to the coil + side in the run position. Only the start position so it fires. Let the key go and it stops. You need to figure out why there's no power from the key switch to the coil in the run position. The terminal on the switch for the coil is (Or should be) marked " I " on the back Maybe some more background info would help internet diagnostics New to you tractor? Or it's been running fine and this just popped up? Was anything changed on it? Switch, coil etc etc Is this an original motor? Kohler made K301 and M12 which have different ignition systems. Any new wiring done recently? Anything else? Edited April 24, 2023 by wallfish 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,176 #5 Posted April 24, 2023 Here is a page on the ignition switch and how it should function. Click on the picture 1 Share this post Link to post Share on other sites
953 nut 56,742 #6 Posted April 24, 2023 1 hour ago, Frank DeHaven said: Okay so I have my engine running but it seems like I have to keep the key turn to the start position or the engine will shut off. I have a new coil, condenser, and points. Does anyone have any other suggestions? My tractor is a c120 automatic with a 12 horse power Kohler. Thanks in advance On your other post you showed a new ignition switch you were installing. Is it a 103-990 switch? Is the "I" terminal of the ignition switch connected to the "+" terminal of the ignition coil? Is the "S" terminal of the ignition switch connected to the small terminal of your starter solenoid and nothing else? 1 Share this post Link to post Share on other sites
Pullstart 63,529 #7 Posted April 25, 2023 Good investigating @953 nut! 1 Share this post Link to post Share on other sites
hotajax 225 #8 Posted April 25, 2023 On 4/24/2023 at 5:44 PM, squonk said: Sounds like a bad key switch if the wiring hasn't been altered. Fortunately, key switches are cheap, I saw one in Lowe's and it fit. Share this post Link to post Share on other sites
953 nut 56,742 #9 Posted April 25, 2023 13 minutes ago, hotajax said: Fortunately, key switches are cheap, I saw one in Lowe's and it fit. It fit but was it correct for your application? Is this relative to this thread? Share this post Link to post Share on other sites
hotajax 225 #10 Posted April 26, 2023 (edited) 4 hours ago, hotajax said: Fortunately, key switches are cheap, I saw one in Lowe's and it fit. Edited April 26, 2023 by hotajax Responded to Wrong Thread Share this post Link to post Share on other sites
hotajax 225 #11 Posted April 26, 2023 4 hours ago, 953 nut said: It fit but was it correct for your application? Is this relative to this thread? Share this post Link to post Share on other sites
ohiofarmer 3,314 #12 Posted April 26, 2023 The real fun begins when the switch has no markings on the back. Then it is time for the continuity tester. It really helped me recently when a wiring schematic was posted for my 314-8 The factory part number from Mother Toro was listed ,but that switch from Toro is 48 dollars. Put the part number in the open search internet and ordered two for twenty bucks. The wiring schematic also has each terminal stamped with the letters and a color wiring harness easily traceable Share this post Link to post Share on other sites
Frank DeHaven 27 #13 Posted April 26, 2023 It runs!!!! Had 2 wires switched. Transmission and everything works. Now it's time to tear it apart send it and paint it. Any advice on painting it? 20230425_121252.mp4 1 1 Share this post Link to post Share on other sites
953 nut 56,742 #14 Posted April 27, 2023 10 hours ago, Frank DeHaven said: Any advice on painting it? There are lots of threads on here about painting, restoring etc. One of the best is Hanks 854 below, take the time to read it from start to end. 1 Share this post Link to post Share on other sites
