Monstrosity
SEAT TIME SATURDAY!!
Monstrosity
Show off what your doing from the seat of your Horse!!! Fixed up a mowing deck for the 1277 and put the plow on the C1014. Getting ready to level a topsoil pile and going down the block to mow the small park to test the mowing deck out.20230422_170710.jpg.934970b275dd11c3371668baed3ac003.jpg
  • Like 4
  • Excellent 1
c-series don
From one firefighter to another shouldn’t you have a screen on that burn barrel?🤣🤣😂
  • Haha 1
Monstrosity
Ha! We yern for chaos!! Plus you can't fit the big stuff in with one on 🤣🤣
Edited by Monstrosity
  • Excellent 1
  • Haha 2
Pullstart
  • Excellent 5
Monstrosity
It's not a horse but it'll do. In maytown PA  today at my parents place put up a temporary fence and drove the kiddos around on with the Husq. Shed  is getting torn down soon and putting up a steel building cant wait for my next trip.....lol while im here anyone got some cheap wheel weights?????20230429_181142.jpg.c0aeab152c6365c54910af42646764d6.jpg
kpinnc
For anyone doubting the advantage of upgrading to LED headlights:
  • Excellent 3
Retired Wrencher
I ride it. And listen to that Kohler power. I enjoy the ride.
  • Excellent 2
Retired Wrencher
What do those bulbs go fro as a rule.
kpinnc
About $35 a pair last set I ordered. Just PAR 36 LEDs.
Retired Wrencher
Looks like they do work. Is there P/N and make or model for these? I will look into it. Thanks for any info.
kpinnc
I've used these with good results. Good company to deal with too.
PAR 36 style LEDs
I've used the Natural 4000K versions.
Plug and play bulbs. Just make sure you jumper your ground over to the frame from the hood. Prevents flickering.
Edited by kpinnc
  • Excellent 1
Monstrosity
Took the diesel horsey and family down to the park today!
20230506_115611.jpg.46c4dc70ec9992d1a28a9a08824a5fbb.jpg20230506_115638.jpg.61bcc479881728c07735af2438ce78bf.jpgIMG_1825.jpg.d8f9edbbc9fdd8a62c5976ed7c63db5d.jpg
  • Thanks 1
  • Heart 2
  • Similar Content
    • Treepep
      By Treepep
      1975-77 Yanmar YM2000Z.  I got as a basket case and did a lot of work on it.  Tractor only but I have a new Jbar brush hog that can go with it.  954 hours.  It slips out of high gears after a bit or uphill.  I Don't know if that is an easy fix.  New starter fuel pump to tank.  All new belts hoses etc.  new front tires and tubes.  rear are original.
      Its been a couple years since new parts but covered and cared for.  Feel free to ask any questions.  I could maybe deliver to a reasonable area.  Health says its time.  I need less responsibility and maint.  These machines need to continue to move or they wont.
      Thanks guys.  Pictures soon.  about 40 minutes south from my place.
    • wh315-8
      By wh315-8
      This is a tag on a 1970 Raider 10 from someone on a FB group. Never seen one that had USED on it, it is Model 1-6041 U
                Serial  342 USED.
      owner thought tag reads 2-6041 U for model but not sure.
      I just wonder if this was perhaps a warranty factory return and they used a new id tag this way?
      Anyone ever come across something like this?
       Typed in the numbers for Clarity.
    • Donavon1
      By Donavon1
      Need some help deciding on a brand of engine to buy for my 1054. (Needs to be a diesel 10 hp+) I’m refining used motor oil/cooking oil for fuel for it. So it will have to have an option to run used oil and diesel
    • Joe Reese
      By Joe Reese
      518H Project/Roller Cash - As Is Has last compression/spark last i checked, currently not running. Gauges work when hooked up to battery and engine turns over freely, Has new fuel pump & carb. Comes with original carb & parts
    • Joe Reese
      By Joe Reese
      60 Inch wheel horse mower deck with no rot. All spindles greased and spin smoothly. Comes with mule pulley guard & deck belt covers and the rare offset front mule. Has standard blades installed. Have brand new gator mulching blades for an additional $50 Great       Joe Reese
