John2189
656 Wheel Horse
John2189
image.jpeg.6c2abb0f71b4514d6adb04f4d0e0e1e1.jpeg  Hi. What would the original seat look like and do you think this is the original steering wheel?
Thanks John
  • Like 4
  • Excellent 3
Achto
Seat & steering wheel are not correct for that tractor.
These pictures are of a 867. The seat is not original, but as close as I could find new. Your seat should look similar. Your steering wheel should be the same as the one in the pictures.
I believe that I purchased the seat from - https://www.wheelhorseforum.com/forum/177-kb-horse-parts/
Edited by Achto
  • Like 4
Pullstart
John, are you planning a restore?  That thing has tons of character the way it is.  As long as the seat is comfy, run it :handgestures-thumbupright:
953 nut
:text-coolphotos:                 A little TLC and a good bath should make it a great worker. :twocents-02cents:   The belt guard needs to be replaced or you will be grinding a few gears.
John2189
No to the restore, I’m leaving it as is. Seat is ok but it is hard to get on it. Im short and fat😊. I thought maybe a low back would be easier to get on.
John2189
I don’t think it grinds, but I think ill try to find a belt guard
John2189
What belt guard will fit this?  Only the one for the 656?
Achto
Most belt guards from a square hood ('65 - early '70's) with a Tecumseh engine will fit your tractor.
kpinnc
Those are pictures of a beautiful 867! Very nice! :thumbs:
oliver2-44
Sell me that sickle mower so you can afford to go buy a seat, steering wheel and belt guard :ychain:
  • Haha 2
Rob J.
Rob J.
Just now, Rob J. said:
It was a one piece not a two piece like this one.
Rob J.
Rob J.
This seat was the last one made like this by Bob Ellison.
John2189
Thanks  are they readily available?  Maybe I will post an add in the wanted section
John2189
4 hours ago, Rob J. said:
Is this what my guard should look like?
Achto
Similar, yes. The front mounting tab for a Tecumseh is different than one for a Kohler. If you look at the pic below you can see that the mounting tab for the engine is in the middle of the guard in front instead of on top of the guard. Other than the engine missing, the 656 pictured below looks fairly factory correct.
656_wheel_horse002.jpg.d8ff2148fcc84f7100e4cdafbcdeacec.jpg.f75c1be99995522789c830cecc228dff.jpg
Edited by Achto
Rob J.
Rob J.
That’s what your 656 should look like but with a one piece seat.
John2189
Thanks.
