brians306 23 #1 Posted April 15, 2023 Hello all. just curious if all you pullers weld the rear axles? 1 Share this post Link to post Share on other sites
Pullstart 64,351 #2 Posted April 15, 2023 Some people flip every other pinion, effectively locking the differential… 4 Share this post Link to post Share on other sites
brians306 23 #3 Posted April 16, 2023 On 4/14/2023 at 9:30 PM, Pullstart said: Some people flip every other pinion, effectively locking the differential… I would assume you are speaking of the 8 pinion trans,? Share this post Link to post Share on other sites
Pullstart 64,351 #4 Posted April 16, 2023 1 minute ago, brians306 said: I would assume you are speaking of the 8 pinion trans,? I think people have done 8 and 10 pinions. 3 Share this post Link to post Share on other sites
Oldskool 6,660 #5 Posted April 16, 2023 @ebinmaine did you lock yours? Share this post Link to post Share on other sites
ebinmaine 70,300 #6 Posted April 16, 2023 11 minutes ago, Oldskool said: @ebinmaine did you lock yours? No sir. No need. My tractors are built HEAVY so I get traction. Also worth considering is that a locked rear does NOT want to turn. I've had great concerns about breaking an axle so I leave all our machines as either Open Diff 8 speeds or Limited Slip Differential 6 speeds. 1 hour ago, Pullstart said: I think people have done 8 and 10 pinions. 8 pinions I've seen. 10 I haven't. IMHO it's pointless to weld or lock a 10 pinion because it's already a Limited Slip Differential. Locking up a 10 pinion could lead to easier damage than an 8 pinion because the pinions are smaller and the end plates are not as strong. 2 4 Share this post Link to post Share on other sites
Pullstart 64,351 #7 Posted April 16, 2023 Obviously, this is not a guarantee that it’ll perform or last as you expect. These are not trucks and are sometimes treated as such. Individual results may vary 3 2 Share this post Link to post Share on other sites
ri702bill 8,902 #8 Posted April 22, 2023 On 4/16/2023 at 7:38 PM, Pullstart said: Individual results may vary Recommended for ages 8 and above - some assembly required, batteries not included, may not be exactly as pictured, etc..... 3 Share this post Link to post Share on other sites
brians306 23 #9 Posted April 28, 2023 On 4/14/2023 at 9:30 PM, Pullstart said: Some people flip every other pinion, effectively locking the differential… I flipped every other pinion and it locked one side. the other axle spins free. Not engaging the pinions Share this post Link to post Share on other sites
ebinmaine 70,300 #10 Posted April 29, 2023 27 minutes ago, brians306 said: I flipped every other pinion and it locked one side. the other axle spins free. Not engaging the pinions How many pinions? If it's a 10 pinion it might not lock that way. Only 8 pinion diffs work that way and each set in sequence needs to be opposite. Share this post Link to post Share on other sites
brians306 23 #11 Posted April 29, 2023 1 hour ago, ebinmaine said: How many pinions? If it's a 10 pinion it might not lock that way. Only 8 pinion diffs work that way and each set in sequence needs to be opposite. Its an 8 pinion. so your saying not every other one. but every other set? 1 Share this post Link to post Share on other sites
ebinmaine 70,300 #12 Posted April 29, 2023 35 minutes ago, brians306 said: Its an 8 pinion. so your saying not every other one. but every other set? In stock form it's every other pinion. To lock it, have two opposing sets of two headed the same direction. I have an 8 speed open on the bench so I can get you pics tomorrow morning if it helps. 1 Share this post Link to post Share on other sites
brians306 23 #13 Posted April 29, 2023 19 minutes ago, ebinmaine said: In stock form it's every other pinion. To lock it, have two opposing sets of two headed the same direction. I have an 8 speed open on the bench so I can get you pics tomorrow morning if it helps. I understand now thanks for the help.. 1 Share this post Link to post Share on other sites
Toby Stockman 87 #14 Posted July 20, 2024 yep i locked my pullers done a 8 speed and a 3 speed works great but you will go through tires like you wouldnt belive even on dirt/grass Share this post Link to post Share on other sites
Lee1977 6,991 #15 Posted September 14, 2024 Those that speed them up and trail ride through the woods weld the differential. One reason is traction the other is to have brakes on steep hills. Braking one wheel will lock and the other will freewheel 2 Share this post Link to post Share on other sites
adsm08 2,556 #16 Posted September 14, 2024 On 4/16/2023 at 11:11 AM, ebinmaine said: IMHO it's pointless to weld or lock a 10 pinion because it's already a Limited Slip Differential. Locking up a 10 pinion could lead to easier damage than an 8 pinion because the pinions are smaller and the end plates are not as strong. Not necessarily. Limited slip takes half the power of the wheel slipping and sends it to the other wheel. It is very easy to get just as stuck with and LSD as you would be with an open rear. Half of zero is still zero afterall. How the power transferred also makes a difference in how well it works. Clutch-style LSDs tend to be more susceptible to that kind of issue. Torsen units, which more closely resemble the 10-pinion rears, are better. They have a lower torque bias and so if you have one wheel standing still and the other spinning fast enough you get get a Torsen to act like a locker. 1 Share this post Link to post Share on other sites
RandyLittrell 3,894 #17 Posted October 7, 2024 I pulled garden tractors for a long time and none of the pullers I pulled with locked the diff. You really don't need it, I never had just one tire spin out. Randy 1 Share this post Link to post Share on other sites
