diesel life
Front end loader
diesel life
I was just thinking that with the lovejoy you wouldn't have to worry about belt tension and or slippage. Its just a thought I haven't figured out exactly how I'm going to do it yet. Just got the 520 tuned up an new belt waiting on a tensioner pelley wich is hard to find, I'm actually going to be using a hustler deck pulley same dimensions and about $70 cheaper. Then we will start working on the loader frame and hydraulics. The loader has a tank in the arm of it but it looks pretty dirty in there , would it be better to run an tank mounted somewhere else?
JCM
Some pictures of a Kwik- Way setup for you on a 417-8 and a 520-H.
  • Excellent 3
Thor27
Nice score. Here is a few pics of building my frame, and pump mount that may or may not help
It helps to have a spare striped tractor or 10 to mock it up on.
20211219_170842.jpg.112bbc4575d64532eaf359e3d1f2bfc9.jpg.024c321064fe60d543e2d09624493ac9.jpg
there is a 5/8 bolt that runs up from the bottom to put this in tension, The U pieces were cut from a drop 0f 4x6 1/4" rect tube. On the top I used 1/2" bolts with nuts
welded to the front upright instead of pins because its easier to put on and remove ( you don't have to pull the wheels.
20211219_170829.jpg.7e53d3d27767aa73702fef1df5c4abc2.jpg.dc456721b8086e21250d7d56a821196e.jpg20211218_162427.jpg.157cd4a4c5fcb87e99fc45ae73c059e7.jpg.d7279a6f9dd8595767274fbd86dd16ab.jpg20211226_141438.jpg.b79d108f403aeb7d4f75159f397108d5.jpg.334539453f8ad46aeca9077579125889.jpg20220702_191445.jpg.76def767ea583c956b712970c5aca823.jpg
I just put a piece of plate on the side of tank to mount a filter to,
Thor27
I didn't clean out my tank well enough and it destroyed my original cessna pump in the first hour of use.
My filter is on the return because I didn't want it as low as it the suction hose.
Edited by Thor27
add
