Streetrodchev
Deere 318 and 332
Streetrodchev
  • Excellent 5
Streetrodchev
  • Like 5
  • Excellent 3
Streetrodchev
  • Like 7
Pullstart
Those look pretty dang tough!
  • Like 4
T-Mo
Nice machines.  Tell us more about the pull behind 2 bottom plow.
Nice D in the background of the first image, 2nd post.  I seen a youtube video from a few months back where there was a plow day that just had D's, about 40 of them, that was plowing.  The D, if I remember correctly, was made for 30 years or something like that.
ebinmaine
Excellent builds and upgrades
Streetrodchev
Thanks
Thanks
Both plows were built by Glenn Peterson, the pull type is styled after a Deere 44H plow. It is fully adjustable just like the big plows. Uses 10” Brinly moldboards. Hydraulic lift.
The D was at a show in Edgar, WI. I just happened to setup next to it. The owner was very nice.
I did see the “D” plow day on fb, cool watching them plow.
Some closer pics of the plow.
  • Excellent 4
Streetrodchev
Thank you
OutdoorEnvy
Those look like some serious workers!  That plow is a neat setup for sure.  Thanks for the share!
Streetrodchev
Thank you
Yes, they do my serious work.
J854D
That pull type plow has an amazing likeness to the full size 44H John Deere plow! A farmer I worked for had one that we fixed up and he would take it to plow events and use it behind his John Deere A and B. His 44H was a 14” & 16” adjustable plow. -JD-
peter lena
@Streetrodchev nice looking well kept deers there ! just the opposite of what I  commonly see , that moldboard unit is very stout and incredibly efficient, thank you for sharing , pete
Streetrodchev
Yes, is is styled after a 44H plow.
Thank you
Old School 92
Hi Streetrodchev.  I am considering getting a Deere 318 myself.  You have an awesome build.
Has the 318 ever let you down when it comes to working your garden?
Also, I know you have the 3 point hitch, but do you know anything about using a sleeve hitch on a 318 instead?  I ask because I would want to get implements from Brinley, but all of their stuff is for sleeve hitch, and not 3 point.
T-Mo
Brinly had 3 point implements before.  The 318 would have a category zero 3 point, and there are category zero implements out there.  There is also an adapter you can make or buy that would convert a tractor's 3 point hitch to a sleeve (Deere calls it integral) hitch.
Streetrodchev
Thank you.
The only time my 318 let me down, was the ignition module on the P218 Onan.
I use an adapter for the 3 point to use sleeve hitch attachments. My first couple of years plowing was with a sleeve hitch plow.
Edited by Streetrodchev
