Tonytoro416 1,034 #1 Posted April 1, 2023 Looking to get new choke and throttle cables for our 68 raider build. Obviously takes the round knob pull style with throttle lock. I see several online in various price ranges. Price doesn’t necessarily concern me as much as quality. I saw some posts on here from several years ago and the consensus was most aftermarket ones weren’t worth messing with. Are they still this way today and if so what brand do you all recommend ? Share this post Link to post Share on other sites
Pullstart 62,845 #2 Posted April 1, 2023 @Achto @WHX??? Psep.biz or something? Share this post Link to post Share on other sites
Tonytoro416 1,034 #3 Posted April 1, 2023 1 hour ago, Pullstart said: @Achto @WHX??? Psep.biz or something? ?? Share this post Link to post Share on other sites
ri702bill 8,317 #4 Posted April 1, 2023 (edited) One option, although not an exact copy, is to use repro choke & throttle cables for a WWII Jeep. They look the same, the throttle does not lock unfortunately. Edited April 1, 2023 by ri702bill 1 Share this post Link to post Share on other sites
Thegearhead0324 1,255 #5 Posted April 1, 2023 I bought mine from eBay for my 1257. Works good so far. Usually come longer so you cut to length. Share this post Link to post Share on other sites
squonk 41,096 #6 Posted April 1, 2023 (edited) I get replacement cables at the show. Not cheap and you may have to trim them but they work great. I think you can still get them from Toro. Part #'s Throttle 102119 choke 102118. Vendor is Dave's Small engine Pottsville Pa 717 544 8320 Edited April 1, 2023 by squonk 3 1 Share this post Link to post Share on other sites
ebinmaine 67,462 #7 Posted April 1, 2023 8 hours ago, Pullstart said: @Achto @WHX??? Psep.biz or something? Pat's Small Engine Plus. http://psep.biz/ I ordered 4 throttle cables from them recently. Pricing is excellent. They seem good. Time will tell. Trina's tractors aren't restorations that need to look correct so I ordered less expensive black knobbed pull cables for the chokes from a different place. 2 1 Share this post Link to post Share on other sites
squonk 41,096 #8 Posted April 1, 2023 I also make my cables a tad long. They seem to work better when they have a little give to them. 4 Share this post Link to post Share on other sites
ebinmaine 67,462 #9 Posted April 1, 2023 4 minutes ago, squonk said: I also make my cables a tad long. They seem to work better when they have a little give to them. I do the same. There's a fair difference in ease of operation when you take a little sharpness of the arc out of the cable. 2 Share this post Link to post Share on other sites
ri702bill 8,317 #10 Posted April 1, 2023 44 minutes ago, squonk said: I also make my cables a tad long. They seem to work better when they have a little give to them. Mike - define "tad" - 1" longer, or so?? Share this post Link to post Share on other sites
squonk 41,096 #11 Posted April 1, 2023 (edited) 14 minutes ago, ri702bill said: Mike - define "tad" - 1" longer, or so?? The lengths are in this thread. I tuck the extra conduit under the hood. Edited April 1, 2023 by squonk 2 Share this post Link to post Share on other sites
peter lena 8,620 #12 Posted April 1, 2023 @Tonytoro416 https://www.zoro.com/super-lube-4-oz-hydraulic-oil-bottle-150-iso-viscosity-85w-sae-51004/i/G5124506/? use this in all my cabling , hanging vertical feed , note temp range , also let cable be where it wants to be , so that it works seamlessly . also a dielectric grease . on electrical and very good on gas tank rubber valve seat . for easy installation. just a suggestion , pete 2 Share this post Link to post Share on other sites
WHX?? 48,815 #13 Posted April 1, 2023 Not for what you need Tony but while we're on the subject. @Achto scored some sheath and inner cable off fleabay or the jungle for his 953 resto. This stuff is the cats meow. The sheath has a plastic or nylon inner core that lets the wire slide slicker than snot on a door knob! The 1054 I just picked up from @Shynon had orginals on it that were terrible so i replaced and rerouted with it. Wow what a difference. It should work on any lever style that you can open up the clamp on at the lever. Sheath cuts easy with a cut off wheel & wire forms nice with z bend pliers. It came in a 50 ft roll of sheath and 100 ft roof of wire so enough to do the whole herd. 4 Share this post Link to post Share on other sites
ri702bill 8,317 #14 Posted April 1, 2023 Mike - that's a mighty big tad - more like a tadpole!!! Share this post Link to post Share on other sites
Achto 27,570 #15 Posted April 1, 2023 4 hours ago, WHX?? said: It came in a 50 ft roll of sheath and 100 ft roof of wire so enough to do the whole herd Save me some for my 953. 1 1 Share this post Link to post Share on other sites
Tonytoro416 1,034 #16 Posted April 1, 2023 Thanks guys I appreciate you all 1 Share this post Link to post Share on other sites
WHX?? 48,815 #17 Posted April 1, 2023 4 hours ago, Achto said: Save me some for my 953. Plenty for many more... I told Joel to say he didn't bring it over so I have no idea where it went... I'd like to finger out how one could use it on knob style cables. 2 Share this post Link to post Share on other sites
WHX?? 48,815 #18 Posted April 1, 2023 BTW @Tonytoro416 I have used the ones from pats and the ones off fleabay and they were all the same quality & by Stens. The big thing is lube the inner wire before you put the z bend on. Maybe the stuff suggested by greasy pete. Don't use anti seize like I did. I thought it would be the answer but it interferes with the locking system on the throttle. 1 Share this post Link to post Share on other sites
