Thompson1276 256 #1 Posted March 31, 2023 Update on the 856 it had a raider 10 HH100 now I swapped to a Pennsylvania Panzer HH100 had a larger pulley and some blocks to make it look bigger the other engine also lost spark and this has points so it’ll last way longer than that crap design solid state igniton I don’t know who thought it was a good idea to make solid state ignition but I ever met the guy I’d prob strangle him half to death 2 2 Share this post Link to post Share on other sites
Pullstart 62,848 #2 Posted March 31, 2023 That looks stout! Does the clutch/belt guard still stop the belt well? 1 Share this post Link to post Share on other sites
Achto 27,570 #3 Posted March 31, 2023 (edited) 11 hours ago, Thompson1276 said: I don’t know who thought it was a good idea to make solid state ignition This depends on the manufacturer & design. The Briggs & Stratton solid state ignition is an excellent no trouble system. Fact I convert most B&S engines I run across with points to solid state. Just cut the wire that goes to the points & install a solid state coil, job done. Much easier than pulling the flywheel to mess with the points. Sweet set up in your tractor!! Edited March 31, 2023 by Achto 2 Share this post Link to post Share on other sites
Thompson1276 256 #4 Posted April 1, 2023 On 3/31/2023 at 7:57 AM, Pullstart said: That looks stout! Does the clutch/belt guard still stop the belt well? Yes just fine actually I had to add a pulley though on the frame by the dash are of the frame and snake it like a M then loop around the engine and tbh it helped doing that and also it takes the same belt as a lawn mower deck for a 46 WH 1 Share this post Link to post Share on other sites
