EB-80/8inPA 1,794 #1 Posted March 25, 2023 Last fall I noticed my newest addition 1267 was losing power uphill. I figured it needed a governor adjustment, resolved to address it in the Spring and put it away for the winter. Having determined the governor was fine this week, I assumed it was fuel delivery related. I also noticed the oil smelled gassy. I replaced the fuel pump diaphragm, the lines, the valve (screen was crimped) and blew the crud out of the tank, changed the oil and turned the key. Ran briefly, quit and refused to start again. At this point it was clear the battery was weak, but it would not be jumped. Charged the battery overnight and it took the charge (yay!) and she fired up (yay, again!). But it refused to rev. Adjusting the throttle failed to have any effect, notwithstanding a few blasts of cleaner sprayed in there with great hope. Compression is 90#. The spark plug had liquidy residue on it resembling an oil/gas mix. Oh, and for good measure, while I was futzing with the gas tank I must have bothered a wire or something, as the ignition switch arced briefly and smoked a bit but then acted normal again. Before I start tearing into the carburetor, does anybody have any advice what to focus on first? Thanks in advance. Share this post Link to post Share on other sites
squonk 42,583 #2 Posted March 25, 2023 I would do a cylinder leakage test first. 80 bucks at Harbor Freight 1 1 Share this post Link to post Share on other sites
EB-80/8inPA 1,794 #3 Posted March 25, 2023 (edited) 19 hours ago, squonk said: I would do a cylinder leakage test first. That I will do. I was wondering why that motor seemed to huff and puff. I’m guessing it is leaking. Thanks for the feedback @squonk. Appreciated. Edited March 26, 2023 by EB-80/8inPA Share this post Link to post Share on other sites
Blasterdad 3,039 #4 Posted March 25, 2023 5 hours ago, EB-80/8inPA said: I must have bothered a wire or something, as the ignition switch arced briefly and smoked a bit but then acted normal again. I would hunt down that Gremlin & look for others too !!! 1 Share this post Link to post Share on other sites
EB-80/8inPA 1,794 #5 Posted March 26, 2023 2 hours ago, Blasterdad said: I would hunt down that Gremlin & look for others too !!! Yeah, that’s a whole ’nother complication right there of no small concern. 1 Share this post Link to post Share on other sites
Ed Kennell 40,517 #6 Posted March 26, 2023 Think clogged muffler ? 1 1 Share this post Link to post Share on other sites
EB-80/8inPA 1,794 #7 Posted March 26, 2023 (edited) 1 hour ago, Ed Kennell said: Think clogged muffler ? Thank you. The thought had not occurred to me. I suspect I’ll be moving into the rusted-in-place muffler removal phase of this diagnostic misadventure next. Edited March 26, 2023 by EB-80/8inPA Share this post Link to post Share on other sites
Ed Kennell 40,517 #8 Posted March 26, 2023 37 minutes ago, EB-80/8inPA said: Is there a way to check that without removing it? Best to take it off to see if it solves the problem. Share this post Link to post Share on other sites
EB-80/8inPA 1,794 #9 Posted March 26, 2023 2 hours ago, Ed Kennell said: Best to take it off to see if it solves the problem. Penetrating oil is applied and fingers are crossed… 1 Share this post Link to post Share on other sites
RED-Z06 2,479 #10 Posted March 26, 2023 Id try a fresh plug, and check/clean the points myself 1 1 Share this post Link to post Share on other sites
953 nut 57,995 #11 Posted March 27, 2023 When an engine was running well before storage and has problems when returned to service the first thing to do is clean the contacts of the ignition points. Place a brown paper bag or a dollar bill between the closed contacts on your points and run it back and forth to remove corrosion. Check the gap to be good too. 1 Share this post Link to post Share on other sites
