JCM 10,017 #26 Posted March 21, 2023 2 hours ago, WHX?? said: You would not be sorry Plunge. I got a set right off and they are on more than the bucket. I have a set of clamp on's for the 520 FEL but light stuff only... too much weight out too far loosens up the rear. Thank you Jim. I figured the clamp on type would do that. Many uses for a good set of HD forks Share this post Link to post Share on other sites
stevasaurus 23,048 #27 Posted March 21, 2023 See if this works for you Eric.. If you can open it, you may be able to print the pages you need. It contains all of the transmissions. 1 Share this post Link to post Share on other sites
ebinmaine 70,656 #28 Posted March 21, 2023 12 minutes ago, stevasaurus said: See if this works for you Eric.. If you can open it, you may be able to print the pages you need. It contains all of the transmissions I'd bet the Local Technology Expert Trina could.... 1 Share this post Link to post Share on other sites
ebinmaine 70,656 #29 Posted March 22, 2023 I figured I'd follow Redsquare policy and start a "Wanted" ad. Share this post Link to post Share on other sites
