John2189 503 #1 Posted March 14, 2023 Hi, I’m kicking around the idea of putting a snow blower on my C-165 What blower will fit? And what would I need to mount it to be sure it has everything to mount it? What price range do they go for? im in ne Ohio thanks John 1 Share this post Link to post Share on other sites
ebinmaine 70,717 #2 Posted March 14, 2023 Assuming your c-165 has the original single cylinder Kohler engine you should have plenty of power to run even the larger of the snow blowers. I only have one and I have not used it yet so I'll defer the information to other members here. I seem to see a consensus that most people prefer the tall chute whether it's a single stage or two stage. .. but that's mostly for control and distance. Share this post Link to post Share on other sites
John2189 503 #3 Posted March 14, 2023 11 minutes ago, ebinmaine said: Assuming your c-165 has the original single cylinder Kohler engine you should have plenty of power to run even the larger of the snow blowers. I only have one and I have not used it yet so I'll defer the information to other members here. I seem to see a consensus that most people prefer the tall chute whether it's a single stage or two stage. .. but that's mostly for control and distance. Yes it is the original 16 horse 2 Share this post Link to post Share on other sites
moe1965 752 #4 Posted March 14, 2023 Not sure what part of Ohio you are in I'm 30 miles west of Cleveland not in the snow belt but occasionally get a good 6 to 8 inches. I have a single stage on a C141 and it throws snow quite far with no problem. I have another tractor with a blade for the wet stuff we get from time to time. I paid 100 for my blower that was in good shape that was Seven years ago or so I see they are going for about 150 now around here. 1 1 Share this post Link to post Share on other sites
ebinmaine 70,717 #5 Posted March 14, 2023 5 minutes ago, moe1965 said: going for Excellent pricing compared to the northeast 1 Share this post Link to post Share on other sites
John2189 503 #6 Posted March 14, 2023 8 minutes ago, moe1965 said: Not sure what part of Ohio you are in I'm 30 miles west of Cleveland not in the snow belt but occasionally get a good 6 to 8 inches. I have a single stage on a C141 and it throws snow quite far with no problem. I have another tractor with a blade for the wet stuff we get from time to time. I paid 100 for my blower that was in good shape that was Seven years ago or so I see they are going for about 150 now around here. I’m in Minerva,16 miles east of Canton 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #7 Posted March 14, 2023 1 Share this post Link to post Share on other sites
John2189 503 #8 Posted March 14, 2023 15 minutes ago, gwest_ca said: Thanks so this is the model that will fit my tractor. What does it use for the hitch? The same hitch that the mower deck uses? 1 Share this post Link to post Share on other sites
Racinbob 11,725 #9 Posted March 14, 2023 It just hooks up to the front hitch and then there's a lift arm and flag that connects to the lift arm rock shaft. There are several models that will fit and are basically the same. If you find a tall chute there will be a part that connects to the mid hitch. It supports the chute direction rotator rod. Look at several manuals. You'll find that you aren't limited to that exact model #. If you find one post it here and we can tell you if it's go or no go. 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #11 Posted March 14, 2023 The parts list shows what is required and there are a few loose pieces for the lift when they are removed that often get forgotten and lost. These will fit your tractor. That is what is so great about Wheel Horse. Front quick hitch introduced in 1973. Snowthrower rear frame has a 5/8" diameter round bar. 1973-74 model 6-6212 plus 6-9113 1974 model 6-6213 - (First model to include 8-0221 extensions without the front straight return - just a flat plate) 1975 model 6-6214 - (First model to include 8-0221 [103552 replaced by 93-1617 and 93-1617-01] side extensions with the front straight return. First model to have a cable spool on chute rotating crank) Chute crank support decal 104461. 1976 model 6-6215 ------ Chute crank support decal 104461. This one - 1976 model 66-42ST01 - Chute crank support decal 104461. and this one are likely identical. The model number format changed. 1977 model 76-42ST01 - Chute crank support decal 104461. This one 1978 model 86-42ST01 - Chute crank support decal 104461. and this one 1979 model 96-42ST01 - Chute crank support decal 104461. and this one may be all the same. They started using a different model number for each model year. 1980 model 06-42ST01 - (Last 42" model to use 4 grooved rollers for the chute) 1981-82 model 06-42ST02 - (First model to use plastic collar for the chute but was a retrofit for older models. Last model to use wheels) 1983 model 06-42ST03 - (First model to use skids) 1984-87 model 06-42ST04 - (Last model to use a 3/4" diameter driveshaft) 1987-89 model 06-42ST05 - (First model to use a 7/8" diameter driveshaft) 1990 model 06-42ST06 - (Last model to use a cable to turn the chute) 1991-93 model 06-42ST07 - (First model with tall chute retained by 3 individual grooved retainers) 1993-2001 model 79360 - (2001 and earlier will fit 2002-2007 with kit 105-1503) (1994 first year for replaceable blower housing scraper bar) 2002-2007 model 79362 1 2 Share this post Link to post Share on other sites
John2189 503 #12 Posted March 15, 2023 1 hour ago, gwest_ca said: The parts list shows what is required and there are a few loose pieces for the lift when they are removed that often get forgotten and lost. These will fit your tractor. That is what is so great about Wheel Horse. Front quick hitch introduced in 1973. Snowthrower rear frame has a 5/8" diameter round bar. 1973-74 model 6-6212 plus 6-9113 1974 model 6-6213 - (First model to include 8-0221 extensions without the front straight return - just a flat plate) 1975 model 6-6214 - (First model to include 8-0221 [103552 replaced by 93-1617 and 93-1617-01] side extensions with the front straight return. First model to have a cable spool on chute rotating crank) Chute crank support decal 104461. 1976 model 6-6215 ------ Chute crank support decal 104461. This one - 1976 model 66-42ST01 - Chute crank support decal 104461. and this one are likely identical. The model number format changed. 1977 model 76-42ST01 - Chute crank support decal 104461. This one 1978 model 86-42ST01 - Chute crank support decal 104461. and this one 1979 model 96-42ST01 - Chute crank support decal 104461. and this one may be all the same. They started using a different model number for each model year. 1980 model 06-42ST01 - (Last 42" model to use 4 grooved rollers for the chute) 1981-82 model 06-42ST02 - (First model to use plastic collar for the chute but was a retrofit for older models. Last model to use wheels) 1983 model 06-42ST03 - (First model to use skids) 1984-87 model 06-42ST04 - (Last model to use a 3/4" diameter driveshaft) 1987-89 model 06-42ST05 - (First model to use a 7/8" diameter driveshaft) 1990 model 06-42ST06 - (Last model to use a cable to turn the chute) 1991-93 model 06-42ST07 - (First model with tall chute retained by 3 individual grooved retainers) 1993-2001 model 79360 - (2001 and earlier will fit 2002-2007 with kit 105-1503) (1994 first year for replaceable blower housing scraper bar) 2002-2007 model 79362 So pretty much any blower will fit? 1 Share this post Link to post Share on other sites
Racinbob 11,725 #13 Posted March 15, 2023 6 minutes ago, John2189 said: So pretty much any blower will fit? That's an awesome amount of information. Yes, they will all fit. Share this post Link to post Share on other sites
Racinbob 11,725 #14 Posted March 15, 2023 (edited) 9 minutes ago, John2189 said: Edited March 15, 2023 by Racinbob Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #15 Posted March 15, 2023 Follow the model numbers. The snowthrowers for tractors with vertical engine crankshafts can look the same to the untrained eye but not work. All in the above list will fit and slight improvements are listed. 1 1 Share this post Link to post Share on other sites
