Tonytoro416
6 speed detent spring
Tonytoro416
Was wondering if the detent spring for the shifter rails was a special spring or has anyone been able to find locally at parts store or hardware store that worked fine. I believe the spring should be 1/4” x 1 1/8”.  The spring rate is what I am concerned about as far as getting one from hardware store or something  thanks guys
Wild Bill 633
@Tonytoro416
If you are referring to IPL Item No. 36, P/N 3518, which has been superseded to P/N 106030 is still available from Toro, $1.97 from SEPW.
