Mike'sHorseBarn 3,133 #26 Posted March 13, 2023 3 hours ago, WHX?? said: That's weird. I might have it backwards tho. Does your 161s have the offset lever Mike? Yea my 161's have the offset lever. 1 Share this post Link to post Share on other sites
peter lena 9,088 #27 Posted March 13, 2023 @ Horseaholic , note last picture down , clear fuel line coming from fuel pump , going to vertical fuel check valve , arrow up , to carb , like the dark green squeeze clamps , build the line , and valve first , then install it complete , makes for an easy fit . have this on my 3 magnum 12 horses , springs on choke / throttle cable , lever arms . pull cables back to close , so you always have a spring assist on lever action , super lube inside cables . no one told me could not do this , so I did it , pete Share this post Link to post Share on other sites
