peter lena 8,589 #1 Posted March 9, 2023 h https://www.amazon.com/gp/product/B0716NGDBQ/ref=pe_27541340_704398030_em_1p_1_lm physical match / type / swap on outer cone bearing upgrade , very easy to re grease , with hi temp lucas . that combined with a inner needle bearing wipe / out , makes for a solidly smooth / quiet lever engagement . next step would be to re grease , the mule drive bearings . only a suggestion , if you like it as it is , ignore this , pete 2 Share this post Link to post Share on other sites
ebinmaine 67,331 #2 Posted March 9, 2023 Are these a press fit type bearing that can be changed fairly easily? @GAJoe 1 Share this post Link to post Share on other sites
squonk 41,041 #3 Posted March 9, 2023 (edited) The 6207 bearing in the link is a 35MM ( 1.38" ) I.D. X 72MM ( 2.83") O.D. X 17MM .67" thick as opposed to the correct 204RR6 bearing which is .75" bore X 1.78" O.D x .61" thick. Good luck making that bearing work! Edited March 9, 2023 by squonk 2 Share this post Link to post Share on other sites
ebinmaine 67,331 #4 Posted March 9, 2023 57 minutes ago, squonk said: The 6207 bearing in the link is a 35MM ( 1.38" ) I.D. X 72MM ( 2.83") O.D. X 17MM .67" thick as opposed to the correct 204RR6 bearing which is .75" bore X 1.78" O.D x .61" thick. Good luck making that bearing work! Mike, you got a Napa number or fleeeBay link with the right number? I do need a couple. Share this post Link to post Share on other sites
squonk 41,041 #5 Posted March 9, 2023 13 minutes ago, ebinmaine said: Mike, you got a Napa number or fleeeBay link with the right number? I do need a couple. Napa #'s as follows: Best quality 204RR6 Mid grade P204RR6 Economy grade. PP204RR6 Primeline Products # 704250 1 2 Share this post Link to post Share on other sites
peter lena 8,589 #6 Posted March 9, 2023 @ebinmaine sorry about that, when you screw up , might as well as make it a good one ! just an idea , had no intension of doing a deliberate misleading referral . pete 1 Share this post Link to post Share on other sites
ebinmaine 67,331 #7 Posted March 9, 2023 38 minutes ago, peter lena said: @ebinmaine sorry about that, when you screw up , might as well as make it a good one ! just an idea , had no intension of doing a deliberate misleading referral . pete No worries Pete. 1 Share this post Link to post Share on other sites
ri702bill 8,296 #8 Posted March 10, 2023 21 hours ago, squonk said: Napa #'s as follows: Best quality 204RR6 Mid grade P204RR6 Economy grade. PP204RR6 Primeline Products # 704250 I suppose the Primeline Products one comes with a "Tail light Warranty" to boot..??? Share this post Link to post Share on other sites
