pfrederi 18,335 #1 Posted March 3, 2023 I know several of you have them...Question should I get battery or plug in??? 1 Share this post Link to post Share on other sites
ebinmaine 70,792 #2 Posted March 3, 2023 (edited) 2 or 3 years ago I'd have said to stay electric for consistent power. Nowadays... We've been using Ridgid brand battery powered tools for several years. The battery life has gotten better. Last year (?) Trina bought herself a Kobalt brand battery powered chainsaw. It's. Excellent. IF you're going to use it for intermittent cuts AND you can keep a good watch on battery charge... Get a battery powered saw and you'll be happy. Edited March 3, 2023 by ebinmaine Edit FAT finger syndrome Share this post Link to post Share on other sites
pfrederi 18,335 #3 Posted March 3, 2023 Thank you 1 Share this post Link to post Share on other sites
SylvanLakeWH 27,589 #4 Posted March 3, 2023 I have Dewalt 20 v battery powered chain saw and pole saw. Outstanding performance and the batteries fit all my Dewalt hand tools... 1 Share this post Link to post Share on other sites
squonk 42,579 #5 Posted March 3, 2023 I have a little 12V Milwaukee band saw that works great for the little jobs that I do. My last job we had a 20V Dewalt. While it worked well it was cumbersome. Job before that we had a corded Milwaukee that was great. 1 Share this post Link to post Share on other sites
Handy Don 13,340 #6 Posted March 3, 2023 (edited) My advice before buying is to think carefully about the battery platform. Look at all the power tools you’re likely to want to replace over the next 3-5 years--then add the “nice to haves” in there as well! Look for brands that use the same battery(ies) across all the tools on your list. (Unless you are planning commercial- or industrial-level usage, all the major brands will serve you.) Check warranties (HD’s Rigid brand is notably good here) Be sure to get the models with brushless motors, as these give much longer battery life and permit electronic speed control. (As an example, the Milwaukee M12 Impact Drivers use pulsed current and a torque sensor instead of a slipping mechanical clutch to create four different strengths of impact and not overdrive the screws. Other brands include similar capabilities.) Then consider personal preferences. I like the M12s (drill/hammer, impact driver, multitool, circular saw, band saw, hacksall) but for folks with smaller hands, the thicker handles may not be as comfortable. And, they won’t handle the biggest jobs that 20v tools (some using dual batteries) tools--like a chainsaw or hedge trimmer--can handle handily! Others in my family like the M18’s and DeWalts, despite what I consider awkward battery placement. Horses for courses. Lastly, if you are shopping big box stores, make sure to speak with the tool department manager to see if you can negotiate a discount for a multiple-tool purchase or to take a display model of an infrequently used tool. I saved about 40% by buying four tools, an extra battery, and some accessories together. Edited March 3, 2023 by Handy Don 1 1 Share this post Link to post Share on other sites
WHX?? 50,774 #7 Posted March 3, 2023 46 minutes ago, Handy Don said: I like the M12s (drill/hammer, impact driver, multitool, circular saw, band saw, hacksall) I'll second that and go with cordless. The handiest tool I have is a 4 inch M12 grinder. The cord comes out for blade sharpening but for quick jobs like removing burrs, cutting a rusted bolt off or even cut off work nothing like the convinces of grab n go. I could see the same thing in a band saw. 2 Share this post Link to post Share on other sites
Handy Don 13,340 #8 Posted March 3, 2023 8 minutes ago, WHX?? said: I could see the same thing in a band saw. That was last year’s tool that I never knew I needed. Just wow! 2-½” throat (vs. 5” on the M18) but for what I do it’s terrific. A lot of what I used to do with the M12 recip saw is easier and more accurate with the bandsaw. Maybe the grinder is this year’s tool! 2 Share this post Link to post Share on other sites
wallfish 17,506 #9 Posted March 3, 2023 The battery powered bandsaws have a pretty small throat. Great for cutting pipe and angle steel and stuff like that but certainly more portable. The bigger electric unit will have more power and can cut much bigger stuff, plate etc. Plus I clamp mine in the vise by the handle and feed material into for certain things. My preference is the bigger electric saw. Not to often I need to do anything with it very far away from a power outlet. 5 Share this post Link to post Share on other sites
ebinmaine 70,792 #10 Posted March 3, 2023 2 minutes ago, wallfish said: The battery powered bandsaws have a pretty small throat. Great for cutting pipe and angle steel and stuff like that but certainly more portable. The bigger electric unit will have more power and can cut much bigger stuff, plate etc. Plus I clamp mine in the vise by the handle and feed material into for certain things. My preference is the bigger electric saw. Not to often I need to do anything with it very far away from a power outlet. Mr Fish has a very good point. When it comes to bandsaws, size DOES matter. 1 Share this post Link to post Share on other sites
wallfish 17,506 #11 Posted March 3, 2023 Ha, yes, size does matter! I bought a used Milwaukee saw 6-7 years ago. Much cheaper than new and those things are built well so no worries about it being used. 3 1 Share this post Link to post Share on other sites
Handy Don 13,340 #12 Posted March 3, 2023 36 minutes ago, ebinmaine said: Mr Fish has a very good point. When it comes to bandsaws, size DOES matter. Fortunate to have a nearby friend with a stationary bandsaw with 11” throat that I get to use when needed! 2 Share this post Link to post Share on other sites
WHX?? 50,774 #13 Posted March 3, 2023 4 hours ago, Handy Don said: Maybe the grinder is this year’s tool! You won't regret it ... excuse me mine is a M18 & use the bigger battery packs. Brand I don't think matters as they are all junk when they go to hell or don't work. I just have Millwaukee as that's what I started out with and have batteries for when I was a workin stiff. Lots of my tractor buddies use the HF cheapys when in hobbyist mode with no issues. 3 hours ago, wallfish said: Not to often I need to do anything with it very far away from a power outlet. True... and if you got the man cave set up right you'll have a couple those handy retractable cord reels hanging out. 1 Share this post Link to post Share on other sites
ebinmaine 70,792 #14 Posted March 4, 2023 28 minutes ago, WHX?? said: those handy retractable cord reels hanging out. I have one o' them ... It is. The bane. Of my existence. It will properly retract about 1 in 30 times. But... It's important to remember I am regularly defeated by cardboard. 4 1 Share this post Link to post Share on other sites
953 nut 57,985 #15 Posted March 4, 2023 I have been using my Milwaukee Port-A-Band for over twenty-five years, they are tough as nails and trouble free. The only way I'd have to replace it is if it were stolen because it will outlive me. If I needed to replace it I wouldn't think twice about buying another corded Port-A-Band. Battery powered tools just aren't as powerful as corded ones in my opinion. 3 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,360 #16 Posted March 4, 2023 I have a Milwaukee Port Band corded, about 20 plus years old, getting heavier every year , but I would not replace with a battery unit. Always cuts straight and blades last a long time. 4 Share this post Link to post Share on other sites
WHX?? 50,774 #17 Posted March 4, 2023 27 minutes ago, ebinmaine said: I have one o' them ... It will properly retract about 1 in 30 times. You got robbed mine all work perfectly. 1 Share this post Link to post Share on other sites
ebinmaine 70,792 #18 Posted March 4, 2023 3 minutes ago, WHX?? said: You got robbed mine all work perfectly. It was free. Likely has a bit too much cord in it. Also me as an operator. 2 Share this post Link to post Share on other sites
8ntruck 7,395 #19 Posted March 4, 2023 The high school robotics team I mentor got a pair of DeWalt corded band saws last fall. They mounted them on bench top tables. They work well, and they survived our build season - lord only knows what all the students ran through them. 1 Share this post Link to post Share on other sites
wallfish 17,506 #20 Posted March 4, 2023 6 hours ago, Handy Don said: Fortunate to have a nearby friend with a stationary bandsaw with 11” throat that I get to use when needed! I found a nice Hz saw way back when building the hoe. Super nice to be able cut big heavy stuff more quick and accurate or multiple pieces at a time plus you can work on other stuff while it's cutting. Found it used on CL too. Almost new Grizzly model. The guy had all the blade adjustments screwed up and even had it in his ad about how the thing won't cut straight. 3 Share this post Link to post Share on other sites
ri702bill 8,993 #21 Posted March 4, 2023 10 hours ago, wallfish said: I found a nice Hz saw way back when building the hoe. Super nice to be able cut big heavy stuff more quick and accurate or multiple pieces at a time plus you can work on other stuff while it's cutting. Found it used on CL too. Almost new Grizzly model. The guy had all the blade adjustments screwed up and even had it in his ad about how the thing won't cut straight. John - I have both the HF Portable 110 volt hand-held bandsaw an their 6" horizontal / vertical bandsaw. No tracking issues at all on the hand-held; the other took a couple of tries, a few simple improvements and a half a pot of coffee.to get it right.... their detachable "cutting table" for the handy vertical setup is a downright joke - made a larger, more rugged version - works well ... Share this post Link to post Share on other sites
Handy Don 13,340 #22 Posted March 4, 2023 17 hours ago, WHX?? said: excuse me mine is a M18 & use the bigger battery packs From your comment, went online and discovered the same. But the M12 line does offer a Die Grinder that looks VERY neat, fitting nicely between a Dremel and an angle grinder! There are both straight and 90º versions. Not sure which makes more sense--the 90º is like a drill/impact shape; the straight is like a Dremel. Share this post Link to post Share on other sites
WHX?? 50,774 #23 Posted March 4, 2023 37 minutes ago, Handy Don said: But the M12 line does offer a Die Grinder that looks VERY neat, Now I gotta go look... might be handy for removing weld spatter?!?! Share this post Link to post Share on other sites
Handy Don 13,340 #24 Posted March 4, 2023 11 minutes ago, WHX?? said: Now I gotta go look... might be handy for removing weld spatter?!?! I’ll be interested in your thoughts on this! Share this post Link to post Share on other sites
WHX?? 50,774 #25 Posted March 4, 2023 (edited) https://www.milwaukeetool.com/Products/2485-20 I need to stay away from that site...talk about red porn... ' course that 3/8 M12 ratchet had a nice figure... Looks to be a bit bulky but no air hose to knuckle around. Prolly best with the bigger battery packs. Like the speed control but doesn't say what max rpm is. Edited March 4, 2023 by WHX?? 1 Share this post Link to post Share on other sites
