TonyToro Jr. 1,408 #1 Posted March 1, 2023 I’m wondering which is a better snowblower? Short or a long chute I have a long chute and it does a good job. Would a short chute do better? 2 Share this post Link to post Share on other sites
ri702bill 8,296 #2 Posted March 1, 2023 Most folks will say the long chute works better, throws the snow further, and since the snow seems to move faster thru it, the chute clogs less. 6 1 Share this post Link to post Share on other sites
Ed Kennell 38,049 #3 Posted March 2, 2023 The better design chute rotator is another reason to stay with the tall chute. 5 1 Share this post Link to post Share on other sites
peter lena 8,589 #4 Posted March 2, 2023 @ tony toro jr. its the type of snow you get , typically is wet and heavy here , short chute is very good , if you are lucky enough to get dry light snow , tall chute is party time . personally lubricate every related snow slide point , also put a ball on the end of my chute rotator rod , very good with mittens , pete 1 1 Share this post Link to post Share on other sites
TonyToro Jr. 1,408 #5 Posted March 2, 2023 @peter lena Yes, i always make sure the grease and lube everything on the blower before and after a Storm. 4 Share this post Link to post Share on other sites
The Freightliner Guy 1,327 #6 Posted March 2, 2023 (edited) the best snow blowers are the metal ones not the junk plastic ones and i prefer the longer one so it shutes farther. Edited March 2, 2023 by The Freightliner Guy 2 Share this post Link to post Share on other sites
wallfish 16,988 #7 Posted March 2, 2023 The curve of the short chute is lower than the tall one so the snow blasts right into it harder rather than sliding through the curve like the tall chute. Keep the blower loaded with snow. Enough so the governor is just kicking in and that seems to be the sweet spot for performance. Do Not go slow into wet heavy snow or it will clog quickly. Load it up fast and it will blast out. Experiment with it! 1 3 Share this post Link to post Share on other sites
Ed Kennell 38,049 #8 Posted March 2, 2023 22 minutes ago, wallfish said: Keep the blower loaded with snow Exactly what's need to make the single stages work in the wet stuff. That's why HP and Hydros are the friend of a single stage. 3 1 Share this post Link to post Share on other sites
TonyToro Jr. 1,408 #9 Posted March 2, 2023 What do you guys recommend for using inside the chute and drum? Share this post Link to post Share on other sites
Ed Kennell 38,049 #10 Posted March 2, 2023 1 minute ago, TonyToro Jr. said: What do you guys recommend for using inside the chute and drum? I buy old outdated cooking spray for cheap. Then Pam it. 4 1 Share this post Link to post Share on other sites
peter lena 8,589 #11 Posted March 2, 2023 @ tony toro jr. keep auger chain lubricated , also the idler pully frame right behind the blower , if the frame can move the pulleys work better at spring pull tension . pete 1 Share this post Link to post Share on other sites
wallfish 16,988 #12 Posted March 3, 2023 2 hours ago, TonyToro Jr. said: What do you guys recommend for using inside the chute and drum? I've used just about every spray thing from Sno-Jet down to $0.50 cans of funiture polish from the outlet store. Believe it or not the furniture polish worked too just like the Pam. Just about anything gets worn off each session by the time your done 3 1 Share this post Link to post Share on other sites
peter lena 8,589 #13 Posted March 3, 2023 @wallfish regularly refer to what I have done / experimented with / tried . thats how I go after a problem , chronic issue . if nothing else make an attempt with any lubricant , found that once a lubricant stains into paint , that is your slide foundation . rarely have any snow hold onto oiled paint . my plow blade is always slick . did a lot of trials on blower function , changed the belt tension spring , on idler pulley frame , re greased the pulleys , and related drive function . blower spun by hand, detailed in the chute slide base , also detailed in the lever crank set up . guy I sold the blower to , was amazed at how easily every stage of it worked . gave him a maintenance page of info . just my own take on horse , opportunities. pete 1 Share this post Link to post Share on other sites
pfrederi 17,685 #14 Posted March 3, 2023 Unless something happens in the next month it will be two years in a row the snowblower tractor went unused. I have a walk behind that hasn't been use in 4 or 5 years... Share this post Link to post Share on other sites
Ed Kennell 38,049 #15 Posted March 3, 2023 1 hour ago, pfrederi said: Unless something happens in the next month it will be two years in a row the snowblower tractor went unused. I have a walk behind that hasn't been use in 4 or 5 years... I changed my blowers to plows 5 years ago. Did not plow snow at all this year. Two snow machines may go on the block next year. 1 Share this post Link to post Share on other sites
