ebinmaine 67,334 #51 Posted March 2, 2023 10 minutes ago, Sailman said: "Digger" my C-120 came with those tires on the back and they work great with my front push blade. Pushed a whole lot of dirt and gravel with that tractor! Going to add the same tread to the fronts since steering traction when pushing was the only weak area. Can you post a pic of the tires that are on the back of your c-120? I couldn't find these in a large enough size... Share this post Link to post Share on other sites
pfrederi 17,685 #53 Posted March 2, 2023 22 hours ago, gwest_ca said: A cubic foot of concrete weighs 150 lbs. A cubic foot of cast iron weighs 450 lbs. Don't be a Wuss Get a cubic foot of depleted uranium 1,175 lbs go big or go home 1 4 1 Share this post Link to post Share on other sites
ebinmaine 67,334 #54 Posted March 2, 2023 26 minutes ago, pfrederi said: Don't be a Wuss Get a cubic foot of depleted uranium 1,175 lbs go big or go home Why does it have to be depleted?? 😄 1 Share this post Link to post Share on other sites
pfrederi 17,685 #55 Posted March 2, 2023 2 minutes ago, ebinmaine said: Why does it have to be depleted?? 😄 Depleted is denser.... 1 Share this post Link to post Share on other sites
ebinmaine 67,334 #56 Posted March 2, 2023 1 minute ago, pfrederi said: Depleted is denser.... Yes yes yes. Share this post Link to post Share on other sites
Sailman 1,291 #57 Posted March 3, 2023 (edited) Eric, Attached are the pictures of the tires. I think they may actually be ATV tires. No telling how old they are or if they are still available. They are great diggers!! Edited March 3, 2023 by Sailman 1 1 Share this post Link to post Share on other sites
Sailman 1,291 #58 Posted March 3, 2023 (edited) Just looked on e-bay and they have these in 23 inch, 24 inch and 25 inch. Enter the following in e-bay search; carlisle AT 489 atv tires AT23 x 10-12 ......but they ain't cheap! Edited March 3, 2023 by Sailman 1 Share this post Link to post Share on other sites
ebinmaine 67,334 #59 Posted March 3, 2023 26 minutes ago, Sailman said: carlisle AT 489 atv tires AT23 x 10-12 Share this post Link to post Share on other sites
953 nut 55,125 #60 Posted March 3, 2023 18 hours ago, pfrederi said: Don't be a Wuss Get a cubic foot of depleted uranium 1,175 lbs go big or go home Built in backup lights with the Cherenkov effect. 1 1 Share this post Link to post Share on other sites
ebinmaine 67,334 #61 Posted March 3, 2023 3 minutes ago, 953 nut said: Built in backup lights with the Cherenkov effect. Probably wouldn't need a battery for the tractor or anything else around either 1 1 Share this post Link to post Share on other sites
pfrederi 17,685 #62 Posted March 3, 2023 1 hour ago, ebinmaine said: Probably wouldn't need a battery for the tractor or anything else around either Sorry depleted uranium will not run your lights... but it will stop bullets from annoying neighbors... used as armor plate on latest generation of M-1 tanks 1 Share this post Link to post Share on other sites
ebinmaine 67,334 #63 Posted March 3, 2023 3 minutes ago, pfrederi said: stop bullets from annoying neighbors To the best of my knowledge none of my neighbors are shooting my direction on purpose but protection from flying metal is always a plus! Share this post Link to post Share on other sites
squonk 41,041 #64 Posted March 3, 2023 One thing overlooked. Weight is fine. But there is only so much the tractor components will tolerate. These aren't Euclid TC-12 dozers we're running. Somethings gotta give and I'd rather have a wheel start to spin as opposed to snapping a gear or axle. 2 Share this post Link to post Share on other sites
OutdoorEnvy 1,522 #65 Posted March 3, 2023 8 minutes ago, ebinmaine said: To the best of my knowledge none of my neighbors are shooting my direction on purpose but protection from flying metal is always a plus! As long as we aren't firing up the kohlers at 3am we can generally avoid being shot at 1 Share this post Link to post Share on other sites
peter lena 8,589 #66 Posted March 3, 2023 @ebinmaine https://www.zoro.com/mason-vibration-iso-pad-3x3x34-in-pk2-2lvr5/i/G3114036/? use this under my rear hitch , forward extension , under trans , stops hitch bounce and insulates against vibration . have what is left of a sheet , mine is orange with circular indents , used it to mount pumps / drives . reference is only for type of trans protection , eliminates hitch , play , sloppiness against impact , pete 1 Share this post Link to post Share on other sites
ebinmaine 67,334 #67 Posted March 3, 2023 3 hours ago, squonk said: One thing overlooked. Weight is fine. But there is only so much the tractor components will tolerate. These aren't Euclid TC-12 dozers we're running. Somethings gotta give and I'd rather have a wheel start to spin as opposed to snapping a gear or axle. Good point to bring forward. Absolutely agreed. I haven't overlooked it. That was in fact the primary reason and one of the first lines in initial post. I want as much weight as the tractor can handle but not at the compromise of durability or SAFETY. For me, yes .. and for the machine. Share this post Link to post Share on other sites
ebinmaine 67,334 #68 Posted March 3, 2023 3 hours ago, OutdoorEnvy said: As long as we aren't firing up the kohlers at 3am we can generally avoid being shot at I've DEFINITELY done that with the odd work schedule that I have..... Share this post Link to post Share on other sites
Sailman 1,291 #69 Posted March 4, 2023 On 3/3/2023 at 9:43 AM, squonk said: One thing overlooked. Weight is fine. But there is only so much the tractor components will tolerate. These aren't Euclid TC-12 dozers we're running. Somethings gotta give and I'd rather have a wheel start to spin as opposed to snapping a gear or axle. What would you folks suggest is a reasonable amount of weight? I am building a box for the 3 pt hitch on my GT 14 and figured if I could get between 200 and 300 lbs. on it I would be good to go. The GT 14 is a heavy tractor to begin with. Also, would like some info on how to put fluid in the rear tires. They are 15 inch with tubes. What say you all?? Share this post Link to post Share on other sites
Handy Don 12,178 #70 Posted March 4, 2023 1 hour ago, Sailman said: What would you folks suggest is a reasonable amount of weight? I am building a box for the 3 pt hitch on my GT 14 and figured if I could get between 200 and 300 lbs. on it I would be good to go. The GT 14 is a heavy tractor to begin with. Also, would like some info on how to put fluid in the rear tires. They are 15 inch with tubes. What say you all?? Not an expert voice but calling out the difference between: - weight in or attached to the wheels/tires (supported at the ground only via tires) vs. - weight attached to the frame (supported by frame, transaxle, and wheel bearings then to the tires and then ground). There is less wear and tear on the tractor from the first than the second. 2 1 Share this post Link to post Share on other sites
ebinmaine 67,334 #71 Posted March 5, 2023 On 3/4/2023 at 11:07 AM, Sailman said: Also, would like some info on how to put fluid in the rear tires. They are 15 inch with tubes. What say you all?? @squonk and @Pullstart have both done videos on fluid filling. I've been running Rimguard Tire Filling Fluid for years. Around here it's at or near the same price as RV antifreeze or even less. Trina and I just did the first set of ours by ourselves. I bought some 5 gallon pails and picked up the Rimguard at the distributor. We used a drill mounted pump. It was... Ok. Dreadfully slow!! But it worked. 1 Share this post Link to post Share on other sites
Pullstart 62,812 #73 Posted March 5, 2023 @Sailman here is a playlist I’ve created on the subject if you care to browse videos Fluid Filling Tractor Tires 1 1 Share this post Link to post Share on other sites
Lee1977 6,651 #74 Posted March 8, 2023 (edited) There's an angle attached to the left side of the receiver hitch bracket with a slot cut in it and the top is bent forward for the chain from the clevis hitch when not attached to the lift. I can also use it for rear attached equipment depth control. Note it's not welded on, it slips on and is helt tight with a set screw from the bottom. Edited March 8, 2023 by Lee1977 3 Share this post Link to post Share on other sites
