maysey 7 #1 Posted February 22, 2023 I have a 14 hp k series kohler. I'm about to do a rebuild on it and noticed it has E16 on the block instead of k321,the bore is right at 3.498. I mainly was wondering what the E16 means. 2 Share this post Link to post Share on other sites
oliver2-44 10,083 #2 Posted February 22, 2023 Lots of knowledge here! Someone will be along that has seen that has seen that before Share this post Link to post Share on other sites
rmaynard 15,805 #3 Posted February 22, 2023 Post a picture of the engine. Sounds like you don't have a K321. What other tags, decals or stickers are on the sheet metal? 2 Share this post Link to post Share on other sites
WHX?? 49,932 #4 Posted February 22, 2023 Yes need a little more info. Is this number cast in the block above crank shaft? Any chance this was a service replacement? 1 Share this post Link to post Share on other sites
Ed Kennell 39,763 #5 Posted February 22, 2023 to the I gotta ask...is Larry the name of this engine with a questionable pedigree? 8 Share this post Link to post Share on other sites
RED-Z06 2,390 #6 Posted February 22, 2023 Got any photos? Share this post Link to post Share on other sites
953 nut 56,764 #7 Posted February 23, 2023 As others have said the E 16 is not a standard Kohler designation. The bore is standard for a 14 HP K-321, did it come out of a Wheel Horse. Share this post Link to post Share on other sites
maysey 7 #8 Posted February 23, 2023 (edited) I made a little mistake on the numbers maybe it looks like E I 6. Sorry guys. Edited February 23, 2023 by maysey 1 Share this post Link to post Share on other sites
953 nut 56,764 #9 Posted February 23, 2023 That is just a mold number. If there was a problem with the castings that would allow the factory to identify and check blocks that were cast in that mold. Share this post Link to post Share on other sites
WHX?? 49,932 #10 Posted February 23, 2023 I have the same tag on a motor on the bench now. The middle I is actually the screwdriver slot holding the plate to the mold. We have saw castings with the model number in the same place tho. It's behind the pto so often goes unnoticed. Share this post Link to post Share on other sites
RED-Z06 2,390 #11 Posted February 23, 2023 3.498 would be a healthy STD sized K321 cylinder... Share this post Link to post Share on other sites
maysey 7 #12 Posted February 23, 2023 Im gonna hone it ten over anyway. below the ridge its wore quite a bit. ive done them before,it just takes a lot of cutting fluid and a little time.Beats paying $100 at the machine shop and waiting 6 weeks. 1 Share this post Link to post Share on other sites
Blasterdad 2,795 #13 Posted February 23, 2023 17 hours ago, Ed Kennell said: to the I gotta ask...is Larry the name of this engine with a questionable pedigree? One question still remains.... 2 Share this post Link to post Share on other sites
RED-Z06 2,390 #14 Posted February 23, 2023 10 minutes ago, maysey said: Im gonna hone it ten over anyway. below the ridge its wore quite a bit. ive done them before,it just takes a lot of cutting fluid and a little time.Beats paying $100 at the machine shop and waiting 6 weeks. You'll never get a straight bore with honing that much material away, the stones will not eat enough of the virgin bore away by the time the worn areas are at target size. Thats why a shop uses a boring bar or rigid hone and finishes the last 0.0005 with a flex hone. Your size of 3.498 is actually on the tight side of standard, might want to measure again if you have a ridge and you measured that size 1 Share this post Link to post Share on other sites
pacer 3,174 #15 Posted February 23, 2023 I believe that a new set of rings would likely put you back to be good for several more yrs, if, indeed your bore is any where close to your measurement... Just hone to remove the glaze and new rings, cheap, quick and a good chance you'd be good. I've done many this way and had good results (disclaimer: this is with wear in the .004/.006 in the cyl) $20 on the bay 1 Share this post Link to post Share on other sites
maysey 7 #16 Posted February 23, 2023 53 minutes ago, RED-Z06 said: You'll never get a straight bore with honing that much material away, the stones will not eat enough of the virgin bore away by the time the worn areas are at target size. Thats why a shop uses a boring bar or rigid hone and finishes the last 0.0005 with a flex hone. Your size of 3.498 is actually on the tight side of standard, might want to measure again if you have a ridge and you measured that size 1 Share this post Link to post Share on other sites
maysey 7 #17 Posted February 23, 2023 I got a rigged hone,not cnc but the rail and bearings are thk 1 Share this post Link to post Share on other sites
Wild Bill 633 862 #18 Posted February 23, 2023 2 hours ago, maysey said: Im gonna hone it ten over anyway. Keep us informed as to how it works out. 2 Share this post Link to post Share on other sites
WHX?? 49,932 #19 Posted February 23, 2023 @pacer guessing you have used those rings? Any good? Just ordered those...a std set for a 301. Share this post Link to post Share on other sites
pacer 3,174 #20 Posted February 24, 2023 19 hours ago, WHX?? said: you have used those rings? Any good? Not necessarily those particular ones, but yes, I have been into some 12-15 Kohlers using using these import engine parts. Have used 5-6 of the full 'rebuild' kits that includes everything including valves (tho I have never needed valves) Now, I will make a ...'disclaimer?' in that I have only ran a couple engines for other than an hour or so, as I was selling the tractors upon completion of the 'refurb' Am presently running a K341 in a D160 that has some 80 hrs on it. Tractor had sat up for long period and I was concerned the rings would be 'stuck' - put new piston, rings and rod in from one of the sites - uses no oil. Next is a K532 with similar condition, it has 40+ hrs on it and will do its first oil change at around 50hrs, though the oil in it appears as clean as when I put it back together. Under ideal circumstances I would like to use .... better?? parts instead of these ...iffy?? import parts, but with these tractors being getting more and more age and wear (along with me!!) I figure the engine will be fine for long enough..... 1 Share this post Link to post Share on other sites
RED-Z06 2,390 #21 Posted February 24, 2023 Kohler oem K/M rings had a chromoly face and took forever to break in...but by golly it was a very tough ring set...you could dust them a few times before they would wear. I imagine most aftermarket ones are just cast rings with a coating. Still a good ring, faster break-in, not as resilient 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,739 #22 Posted February 27, 2023 On 2/23/2023 at 2:21 PM, WHX?? said: @pacer guessing you have used those rings? Any good? Just ordered those...a std set for a 301. I just recently purchased a set of rings and piston from lil red barn on flea bay for a 301. Seem decent quality made in India oddly enough. Vender say he will switching to another manufacturer because of fears of supply issues. 1 Share this post Link to post Share on other sites
WHX?? 49,932 #23 Posted February 27, 2023 Thanks fellas they just came in and upon inspection look to be good enough for the women we go out with. We'll see if I don't break them installing Be sure to check end gaps. They are going in a shelf spare 12. STD bore. 1 Share this post Link to post Share on other sites
Wild Bill 633 862 #24 Posted February 27, 2023 (edited) @WHX?? Hastings Piston Rings makes chrome sets for the Kohler K341-16HP in Std 3.750" P/N 2C5311, 0.020" over P/N 2C5311020 and 0.030" over P/N 2C5311030. Mahle makes Std P/N S41070. Edited February 27, 2023 by Wild Bill 633 1 1 Share this post Link to post Share on other sites
WHX?? 49,932 #25 Posted February 27, 2023 Thanks Bill 633... those PNs help alot for research. Share this post Link to post Share on other sites
